TTR
08-25-2006, 01:19 PM
I finally got my engine running and I have a few questions. This is my first experience with fuel injection so I have a lot to learn.
I got it to start up and idle without any problem but it is eye wateringly rich even though the afr isays its at 14.3. I have leaned it out from there but it sounds best at 14.3. The timing is at 20. I really have only played with the base maps so far. The engine revs pretty freely so I would guess it is in the ballpark. Any ideas? Timing? Injector Phase angle?
Also, I cannot get the ECU to turn on the fuel pump. I have played with the prime time but no luck. I can't seem to find any other tables that address the fuel pump. I have run both the high side and low side connections to the FP relay. I don't seem to get +12 or ground out of either one. I am just manually turning it on right now.
Can anyone recommend a good tuning book? I have Ben Strader's Electronic Fuel Injection book but it does not cover the BS3. There seems to be alot more maps in the BS3 than the ones covered in the book. The BS3 manual leaves alot to be desired. I would like some "cause and effect" explanations.
Stay tuned, more questions to follow I'm sure.
Tim
Tim
