View Full Version : roll cage for a 1971 camaro
psybock
11-04-2004, 02:20 AM
this might sound dumb, but are all roll cages pretty much the same? I realise that some have different tube thickness and diameter, but suppose those were constant, is there one manufacturer that's better than the rest? better quality cage design to fit in my 71 camaro? I've seen some advertised for $200 and others for over $600 for essentially the same setup... what gives?
79T/Aman
11-06-2004, 08:26 PM
the less expessive kits need more fitting ofthe tubes,the more expesive ones don't need as much work,so if you ca cut and fit the tubes yourself you can save some money,olso are you loofing for a roll bar or a roll cage? now if you look at my new web page www.pro-touringf-body.com under the suspension section you'll see my roll bar kit it is designed specifically for 2nd gen. f-cars and for an additional $129.00 it can be upgraded to a cage kit for a total of $328.00 let me know if I can help.
