View Full Version : DSE caster bushings
alky
08-18-2006, 10:32 PM
Hey guys, this may be a stupid question but, which way do the bushings go into the cross shaft? (1969 Camaro)
I was just sitting in my engine compartment and the way I installed them is to physically set the a-arm back toward the rear of the car.
Denny
vanzuuk1
08-19-2006, 05:25 AM
You can install them different ways so you change the caster. Moving the arm back gives more caster. I got grade eight bolts that were longer than the stock uc arm bolts to have room for alignment shims
alky
08-19-2006, 11:27 AM
My question is. How should I start? Before allignment. Is more caster what I want?
tia
Van B
08-19-2006, 01:06 PM
I have been told you want as much caster as possible for high speed stability.
68Formula
08-19-2006, 05:05 PM
Just make sure you have the clearance from the a-arm to the mounting bracket. Dial in as much as you can (move a-arm toward rear of car).
alky
08-20-2006, 09:46 PM
Thanks Guys
