View Full Version : Aerodynamics and drag coefficient
element180
08-18-2006, 04:31 AM
Just wondering if anyone has any info on aerodynamics.Since I doubt any of us has access to a wind tunnel (although knowing the people on this board,I could be wrong),I was just wondering about a few things that apply to real world cars.I've read a bit about drag coefficient and most of them give formulas and scientifical explanations that do nothing more than give me a bloody migrane.I realize it's all about frontal area,but I was just wondering a few thing applying to not only fuel ecomomy,but handling as well...
1.Does the drag coefficient change much,if at all,by lowering the car?
2.How much is it affected by chopping the top,channeling the body over the framerails?
3.How much is it affected by raking the windshield? (I realize it is affected by this but how much and how much rake is required to gain a noticable difference)
4.How much does the rake of the body affect it?I've heard that a 1 degree rake and no rear spoiler seems to be best for a '69 Camaro for example
5.How much do brake cooling ducts affect it?
6.I realize the grill opening adds to the drag coefficient,but how would someone overcome this?
7.What kind of upgrades to the cooling system wound be required to cool the engine if the grille opening size was reduced?
8.How much does an underbody tray affect it?
9.Does tire width play into it at all since most people are going for wider,and wider wheel/tire combos
10.Don't you just hate people like me that ask so many questions in one post
:wedgie:
boodlefoof
08-18-2006, 05:54 AM
Ooh! Fun topic!
I'm by no means an expert on such things, but I did a bit of reading up on this very subject during the design phase of my Datsun 240-Z project. The old Datsuns are anecdotally notorious for being bad aerodynamically. I found some old wind tunnel data on the 240-Z confirming this, indicating that the drag coefficient on a stock-bodied Z is .46!
1) I'm not sure if lowering the car in and of itself will change the drag coefficient much. However, since the underside of most cars is not flat, places such as the lower portion of the rear tail panel can act just like a parachute. If you can reduce the amount of air going into the parachute, you should be better off.
2&3) The Datsun data showed that one of the biggest culprits in that case was the high windshield placed at a high angle. There was a huge pressure system right at the cowl. This makes a cowl induction system work, but it is bad for purposes of drag. There was also a lower pressure system created right above the roof because the air hitting the windshield would separate from the car body as it went up and over the car, promoting lift. By lowering the roof and raking the windshield, you can make for a smoother transition with less drag and possibly reduce lift.
In fact, the lower pressure system over the roofline in the stock-bodied Z is enough to open and raise the rear hatch at highway speeds if it is un-latched!
4) Rake will help to create downforce by helping to create a lower pressure system under the car relative to that going over the top of the car. Not sure how much it would change drag... but it may help just like in your first question.
5) The wheel wells is another "parachute" type of place in the car. I don't know if putting "extra" air into them via a brake duct will increase this effect, but a common solution is to add a vent at the rear of the wheel well to allow the air to escape more easily (like the Corvette).
6&7) When discussing aerodynamics, I have heard it said that the Datsun has "an enormous gaping maw." All the air flowing in there is just getting stuck in the engine bay. The firewall is another parachute type of place. In fact, I've seen pictures of old Zs with fiberglass hoods at even moderate speeds (80) and you can literally see the hood bulging up!
You theoretically want your grill opening to let in just enough air for your cooling system, and then you want to vent that air out from under the hood. Really, I don't think that reducing the grill size some will limit airflow enough to cause problems on most cars. Think about it, if your puller electric fan can only move... say... 2000cfm while you are idling around with no breeze to assist it, you probably don't need a grill opening big enough to flow 20,000 cfm. If you notice, many new cars have incredibly small grill openings compared to older cars.
As for routing the air out after it goes through the radiator, I think the GT-40 hood nostril is probably the best way to do this. Build air-tight ductwork to channel the air so that it only goes through the radiator (lines for brake ducts and such included) and then build another duct to route the air out from under the hood after it goes through the radiator.
To assist airflow through the radiator from a smaller opening, it might help though to tilt the radiator forward.
8) Much like in question 1, there are tons of places where the parachute effect can occur on the underside of the car. Making a smooth belly pan can reduce this effect. I have read however that on a smoother surface the air will better adhere to that surface by friction because there is nothing to agitate the air. Some people seem to think this will cause drag as well, but it seems like a step in the right direction anyway. Some advocate devices (such as vortex generators) to promote agitation as well to reduce friction.
9) The wider the car, the more frontal area, the more drag.
10) I do it too... I can sympathize!
I've actually found out that there is a wind tunnel facility very close to me... if the price isn't too bad (I imagine it is though...), I hope to someday test the Datsun there to see how well (or poorly) I did.
element180
08-18-2006, 06:25 AM
I've read that GM's wind tunnel measured a drag coefficient of .339 for the 1984 Z28,.299 for the Trans Am and .29 for the C5 Vette
I find this a bit hard to believe though
.35 for the Scion xB
boodlefoof
08-18-2006, 03:57 PM
I don't believe that number for the Scion either... that thing is a brick!
The coefficient for a 1990-96 Nissan 300ZX is .31
justanova
08-19-2006, 09:47 AM
http://www.a2wt.com/info.html
here is a wind tunnel place that offers discounts to first timers.
I found this info in this thread over at lateral-g
http://www.lateral-g.net/forums/showthread.php4?t=5569&page=1&pp=10
boodlefoof
08-19-2006, 11:05 AM
Prices don't seem too bad. Hmmm... NC isn't too far either... :D
hotroddr
08-19-2006, 11:44 PM
I have done my share of testing of aerodynamics with my cavalier test mule. It has shown a sizeable increase in gas mileage since the modifications were done. Here is a pic for reference. You may not like the look but everything you see is in the name of aerodynamics.
I covered the grill first with cardboard to determine if it was worthwhile and if the cooling was needed. I found that it did help increase fuel mileage(hard to say how much exactly since I did a lot of things to it for that trip). It also gave the steering a stiffer feel on the freeway. I realize these findings are very unscientific but there was a noticably more solid steering feeling with the grill covered. It ran 20* warmer on the freeway with no increase in temperature on hills. It will heat up a lot in traffic but as soon as the electric fan kicks on its ok.
To comensate for the reduced cooling from having no grill, I decided I could redirect the air that was going under the car through the radiator with an extended and stiffened air dam. The air dam is about an inch and a half lower than it was before and is reinforced with plastic angle to prevent it from collapsing too easily at speed. It is also designed to scrape wherever it wants without falling off. This dropped the temperature 5* from the original operating temp, or 25* from the temp with the grill covered.
The weird looking flaps hanging down under the bumper were intended to direct air around the tires to avoid the turbulence associated with air hitting a spinning tire but I could not tell any difference in feel or gas mileage. I would tend to say its not worth the effort but this was the only configuration I tried and I didnt eliminate enough variables to be sure. They might be more worthwhile on tires bigger than 215s.
I then removed the plastic shields that went between the wheelwell and the engine compartment and the wheelwell to allow engine compartment air to exit the wheelwell. I didnt notice a huge improvement but I think there may have been a little. I did make an interesting observation though. I first removed a piece that blocked air from the front from going around the radiator and noticed a definite decrease in steering feel at speed. I figure this is from the air going through the ex fog light holes bunching up in the wheelwell/engine compartment causing lift. Pics would help you visualize this but I dont have any.
I removed my windshield wipers which improved the looks a little and when it rains the rain blows right off probably because of the smooth air flow without the turbulence produced by the wipers.
The goofy mirrors are from a yamaha R6. I looked at a bunch of different mirrors and found these to look the most aerodynamic. They are not ultimate but Im sure they are better than stock. The stalks are fairly long to keep the flow seperation away from the boundary layer of the body of the car. The stalks are also streamlined and angled towards the back of the car. The body of the mirror is also very smooth. My qualm with these is that the inside part of the mirror body angles towards the window which makes for more noise than if it angled away from the window.
I used to get about 30mpg at 80mph on flat ground and now Im up to 38 mpg so I would say that was a success. You opened a can of worms by starting a discussion on aerodynamics with me. I find it endlessly intriguing. On the list of future tests and experiments with meaningless results: Rear diffusers/venturis, belly pans, rear lips/spoilers, front splitter lengths, vortex generators, speed varying ground clearance and spoiler angle and height, and vents behind the wheelwells for letting out high pressure air from the engine compartment.
element180
08-20-2006, 09:10 AM
I see nothing wrong with the looks.It's about 200% better looking than some of the modded Cav's I've seen on the road with thier goofy assed body kits,rear wings and 20 lbs of vinyl graphics.You do bring up a few points I had'nt htought of
The stalks are fairly long to keep the flow seperation away from the boundary layer of the body of the car. :idea: They remind me of the APR Formula GT3 (http://www.aprperformance.com/proddesc.php?catID=5&subcatID=18&productcategoryID=34) mirrors
Colvindesign
08-20-2006, 10:07 AM
Ok, I actually registered and wrote out a reply to this yesterday, but, when I hit submit, it timed me out and when I hit the back button, I lost everything I wrote, so this time I will copy it right before I submit just in case.
Yes, it will change depending on the amount it is lowered. Depending on the speeds you want to travel at, there is an ideal amount of ground clearance you want. You do not want to be too low at high speeds, as bottoming out can cause a huge change in aerodynamics of the vehicle causing an instant change in steering and traction.
You are going to notice a re-occuring theme with my answers, "It depends on...". This one is, it depends on the make and model of the vehicle AND the amount that is chopped, Channeled. Of course chopping the top and channeling the body over the frame decreases the total frontal area, decreasing the amount of drag. It depends on how much is chopped, and what make and model the vehicle is.
Yet again, it depends on the vehicle. Later model vehicles have laid back windshields, to create downforce. Earlier model vehicles had flat or nearly flat windshields, creating only Drag. But this is a good place to tell you, downforce is also Drag.
Increasing the Rake on the vehicle often times increases the frontal profile, meaning it creates more drag. You will notice that the fastest Bonneville racers have no rake in them.
Cooling ducts on the front of the vehicle for the front brakes are usually placed in turbulant areas to help aerodynamics. Rear ones that protrude from the body increase drag. smaller ones like those on the new Z06 are small enough that the effect they have on the Cd are minimal.
Cover the Grille.
You would need to make improved shrouding and an air intake to direct air into the Radiator, and run electric fans.
Again it really depends on what you want to do. Do you want to hit 200 mph? An underbody pan can be flat, or have aerodynamics worked into it. If it is flat, it simply makes the air travelling under the car move faster without turbulance. If it has aero worked into it (venturi effect) it will act as a spoiler in the front and rear and create downforce, how much depends on the design.
At lower speeds, no. At high speeds, yes. Look at the fastest Bonneville racers again and the ones over 200 mph, most are running very narrow tires. It again decreases the frontal area, but this also decreases the turbulance around the tires and the rolling ressistance.
:wedgie:
More than anything, except I guess for when you write out a long well thought out reply and then lose it because your session logged out, DOH !!!
Basically, it really depends on what you are trying to do. You can increse your aerodynamics enough to make a healthy improvement in your fuel consumption. Teamed with proper tuning for efficiency, larger gains can be had. Or, you can make your 1972 Nova run 200 mph.
If you are not sure, and plan on modifiying a vehicle for one purpose or another, I would recommend talking to a designer (hey, that's what I do!). There are still a few of us out there who will work for nothing, or next to nothing.
Hotroddr, I would like to offer some tips if you don't mind. I really like the look of the Cav you got there, and up to 38 mpg from 30 is really respectable. I might have to get me one of those and do some work on it.
I am sorry if this being my first post makes me look like a know-it-all or something, Really I am doing design work for someone on the board who is hopefully building a 200mph car (I say hopefully because projects fall apart all the time) and he directed me to the thread asking what my imput was on it. I just thought I'd throw my 2 cents in.
- Brian
boodlefoof
08-20-2006, 11:18 AM
Glad to have you aboard Brian! I'm trying to build my Datsun to hit 200mph, so extra input is always welcome from me!
hotroddr, I think your Cavalier looks much better than most I've seen!
ProTouring442
08-20-2006, 11:45 AM
Wow, cool thread! I was looking at the Cavalier, I think it looks better than stock, and way better than most of the modded ones I see.
I have a thought, which becomes a question. On the cooling issues, I wonder what would happen if you opened the area under the chin a bit, then fabricated some sort of air extractor in the hood? I would think this would have a good effect on the cooling issues, but would it help the fuel economy.
On another note, when modifying a car for fuel economy, when do the aero mods really start to make a difference? I know that the "at speed" economy would be much improved, but what about in the 30-50mph range?
Shiny Side Up!
Bill
'72 442 "Inamorata"
element180
08-20-2006, 12:38 PM
Before I go on let me just point out that these are all nothing more than Ideas I have.I don't have the money to do any of this unfortunately
I'm not interested in hitting 200MPH or anything like that.The only car I have right now is a '86 Caprice Classic 4-door with a H-code 305/700R4.If I had the money I'd drop in an LT1.It has minor bolt-on mods.Edelbrock intake and cam,K&N filter.Other than those minor changes everything is dead stock.I average around 22-23mpg.I'm mainly interested in making it a bit different.I've been tossing the idea around of chopping the top an inch or so,channeling the body over the frame and dropping the floor the same amount.This would also give the entire car a lower center of gravity I believe.I know it will never outhandle many cars but a car this big is'nt meant to.The idea of raking the windshield I got from the Smokey Yunick Camaro.Also it just seems like a cool idea.
hotroddr
08-20-2006, 10:29 PM
It can change quite a bit. If you have a 10" (255)wide tire in the front and you lower your car 2" you just decreased your frontal area by 40 in^2. Try holding a 10"x4" plate out your window at speed and tell me if there is a significant force due to wind resistance. This example isnt completely accurate because thats a flat plate as opposed to a tire but its enough to give you an idea. There is a formula for how much drag something produces in a fluid.
https://static1.pt-content.com/images/pt/2006/08/fd2660e8d2c2d8539e3962b48a3ba1c5-1.png
Where the force of drag is equal to half of the density of air times the velocity you are traveling squared times the frontal area times the coefficient of drag. a Z06 for example according to one website has a frontal area of 22.3 square feet. If you decrease your frontal area by a square foot by lowering your car and removing mirrors for example you have made a good dent in drag, a little over 4% reduction in frontal area. (experts please correct me if Im wrong on equations or theory, I think Im pretty close here though)
Another point is that when you lower your car you decrease the amount of air that is able to get under the car and create drag due to the messy undercarriage. This is harder to imagine a quantitative result.
Once again, the depending on how much it is chopped the frontal area is reduced quite a bit. Airflow can also be improved by not forcing the air that you are going through to be displaced as much. When you drive by, all the air that was standing still has to be displaced to allow you to pass. If you reduce the amount of displacement of this air and ease it back to where it was at first with a shape like a tear drop it will decrease the amount of turbulence or drag you will produce.
This is a tough question and one that would take more research for me to answer with any confidence. Reading up about auto manufacturers that have done this might be more enlightening. I have noticed that the new honda civics and the hybrids as well as the new dodge trucks have a very large rake to the windshield and it seems to work for them so I imagine this is worthwhile.
This depends on whether or not you are going to run ground effects or underbody venturis or such. THere are different ways to go about improving aerodynamics of the bottom of the car. It gets confusing a bit when you realize that speeding up air or squeezing it into a smaller space decreases pressure.
I would not worry about brake cooling ducts until you are sure you need them. Make sure you can overheat your brakes even with the right components and clean fluid before you cool them. You might have enough air to cool them for your type of driving just from the engine compartment air exiting the wheelwells. There would be some drage created I imagine by letting air into an opening in the front of the car rather than letting it smoothly go around the side but how much is hard to say, Hopefully someone who knows will chime in.
Like has already been said and proved by me, block it. Try blocking the whole thing with cardboard first, then cut away accordingly if you have to. I extended my air dam instead of opening the grill back up. Make sure you have an electric fan or fan with fan clutch or both for when you sit in traffic.
see above
havent tried it yet but someone did in on a second gen camaro I believe, try searching belly pan and you will find the thread
Yes, see #1 about frontal area. This is another compromise. Is it more important to go fast/get good gas mileage, or to go fast around corners? The honda insight and various other cars I have noticed including my own car have body work to divert air gently around the tires to minimize drag from the tires. I am sure my cobbled together design isnt optimum but I tried. I need a wind tunnel to tell you if it helped.
no.
I have found another unscientific way of testing aerodynamics of different things on your car. I noticed that in the self serve car wash with the high speed pressure washer thing you can see pretty well how air flows around certain parts of your car. I know this doesnt tell you much but it gives you a little idea. I was surprised how much the spoiler on my cavalier launched the air/water. Tufts of yarn or drops of oil also can tell you what air is doing. David pozzi has a link on his website to a coast down approach to figuring out your coefficient of drag without a wind tunnel. I havent had the time to do these things yet. Good discussion here, I am interested in hearing more
Colvindesign
08-21-2006, 06:12 AM
Hey not a problem, let me know the make and mosel of the car and send any pics if you have them.
hotroddr
08-26-2006, 11:11 PM
well..since the last trip where I averaged 38 mpg at 80 mph. I removed the lip from the bottom of the rear bumper and installed new wheels and tires on the cavalier. Today from prescott az to east mesa I averaged 50 mpg still at 80 mph. Even though there is some downhill I would say thats pretty good for a car whose rated highway gas mileage is 33 mpg. If anyone doubted the benefits of small improvements in aerodynamics I hope this takes care of that. i hope more people experiment with these things.
Colvindesign
08-27-2006, 07:56 AM
Nice Work!
More pics please.
hotroddr
08-27-2006, 09:07 PM
ok...here are the pics I have for now. These are the Yamaha R6 mirrors that I used to decrease wind noise and drag. As I mentioned before they could have been designed better but they were an improvement from stock and are smaller in frontal area.
here is the stock mirror for comparison
and another of the motorcycle ones to get an idea of size difference. The motorcycle mirrors are slightly more convex so the viewing angle is wider even though the mirror is smaller.
Here was my initial block off plate for the grill after testing with cardboard
More gains are to be had in decreased drag and increased downforce Im sure by blocking off the rest of the little holes, I just havent gotten around to it.
Here is the extended air dam to compensate for the blocked grill. It is more resistant to collapsing at speed due to the angled support on the back side. Its pretty basic but it works. I have scraped it on lots of things now and even hit stuff on the freeway(including a rabbit and some metal) without ripping it off. I made it from part of a bumper I found in a auto body shop dumpster, yes Im a dumpster diver.
Here is another picture of the front as it was a while ago. I will try to get some updated pictures to give you all more ideas. This car is pretty low. I will measure the height of the air dam and bumper here in the next few days. I cant go over a fast food cup lying on its side without dragging it if that gives you an idea.
These pictures are all older so a few things have changed since then. I hope maybe a few pictures and ideas that have been thrown out here will encourage you all to try some things and report back because there is a lot of improvement to be made in aerodynamics on street cars. I wish I had a lift, some time, and money so I could try it all but that is a few years down the road still.
hotroddr
08-29-2006, 03:23 PM
I hit the jackpot. Here is a link to a pdf that details different ways to reduce drag and the approximate percentages of improvement.
http://www.tfd.chalmers.se/%7Elelo/rvad/reports/rva2002_gr10_drag-reducing.pdf
Colvindesign
08-29-2006, 07:02 PM
lol, that's great info. And put in to laymans' terms.
boodlefoof
08-30-2006, 05:13 AM
I get thefeeling that English wasn't the primary language of the writers, but it gets its point across well.
element180
08-30-2006, 10:56 PM
I like the idea of backup cameras instead of mirrors not to mentio being able to place the monitor/monitors where the driver does'nt have to turn his/her head as much taking they're eyes off the road.I think it would be cool to have the monitor mounted in the headliner and flip down (motorized) when the car is started and back up when it's turned off.Makes for a cleaner look when the power is off
djslik
09-01-2006, 01:43 PM
One thing I remember from my fluid dynamics class is that there have been instances of lowering the drag force on a car to the point of hindering performance. I forget the complete explanation right now and I don't really feel like doing all the math but one of the car manufacturers designed a car with good aerodynamics which resulted in a low drag force. When the car went up hill and down hills they noticed that the car was being less efficient and actually required more fuel consumption and power to overcome the hills because of the low drag force. Frontal area directly affects the drag force and also does the material you are flowing through essentially air. You also have to take into consideration the profile of the front plate because this creates different laminar and turbulent flow profiles. Having a flat frontal area obviously will have more drag force than a rounded front but you also have to think about the turbulance behind the car created from these profiles. With a better aerodynamic shape you have less turbulence behind the car.
Fuelie Fan
09-01-2006, 07:47 PM
I'd like to hear more about that. The only thing i could think of is that you're lowering the load on the engine, resulting in a more efficient operating point on the bsfc map. The cure would probably be to re-gear it. otherwise, P=F*v. if you've lowered F, you've lowered P, and if you've lowered P, you've lowered the amount of fuel that needs to be burned.
element180
09-02-2006, 11:07 AM
My brain hurts :sick:
djslik
09-05-2006, 03:27 PM
I have to do some research if you are really interested I can call up my buddies from college because I know someone knows the exact reasoning behind it, but as far as I can remember, but my memory can be bad sometimes so don't be mad if I'm wrong here, it had some relationship to the pressure behind the car. But I agree my head hurts and I remember why I was happy to finish that class.
Norm Peterson
09-05-2006, 05:08 PM
A couple of related items:
Center of Pressure - as it may move relative to the CG and (I think) resultant tire force, this has directional stability impact. IIRC, aerodynamic refinements to reduce drag move this point rearward.
Induced drag - lift, either upward or downward, is a force that's not purely perpendicular to the road surface. It has a longitudinal drag component.
Norm
hotroddr
09-14-2006, 10:14 PM
It took me long enough but here are the pictures I promised. Really There is nothing that special about what I have done here so far. A lot of it seems to be fairly good design from the factory and I have built on it.
Here is a front shot of the tire air deflectors. I know that these could have been done a lot better but I was in a hurry and the mounting location was convenient. More experimentation is necessary. For reference they are 2" off the ground
This is the view from the front. It looks like the tire sticks out but it really doesnt. Im not sure if it was turned slightly or what.
It appears that there is some room for improvement here. As colvindesign suggested to me, wickers or air deflectors could be implemented here to improve this area. A good example I think of the idea in use is a second generation camaro/firebirds moulding on the front of the wheelwell. It deflects air outward. As I understand it these work like a side spoiler. The area in front of a spoiler whether its on a top surface or a side surface is a high pressure zone due to the air bunching up from trying to get around the spoiler. The area right behind a spoiler is a low pressure zone. On the wheelwell this it desireable because the low pressure zone created in the wheelwell will help to evacuate the air that went through the radiator and into the engine compartment.
here is sami Z01's camaro for an example of air deflectors/wickers/side spoilers in front of the wheel wells
Next we have a picture of the gravel peppered front of the car as it sits now. I need to block off more panels on the front. You can see the extended air dam which sits 3" off the ground. The bumper is 5.5" off the ground. The ex fog light hole on the drivers side is now the air intake. This grill cover is simple but effective. I hope more people try this out(hopefully with more effort put into the paint matching).
I tried to capture the streamlined stalks of the side mirrors here but Its kind of hard to see unless you see it in person. Unfortunately I also got my shoddy thrown together block off panels in the picture as well complete with black primer, D'OH.
This picture doesnt show much since there is not before picture. You couldnt see the transmission from the wheelwell as it was originally because there was a plastic panel there. I removed it to allow the air to exit the wheelwell if it so desires to do so. It was important to not allow any openings in the front part of the inner wheelwell though because that allowed air to bypass the radiator and bunch up in the wheelwell. I made this mistake at first and noticed a difference in steering feel on the freeway.
Here is the rear of the car with the rear lip as it came from the factory
I removed it mainly because I hit something on the freeway and broke some mounting clips but also because it allows air to exit the underside of the car easier. Here it is now without the lip.
Underbody trays or a belly pan as you may with to call it would help a whole bunch Im sure but Im saturated in school, work, ebay, and too many other car projects. The aerodynamics only get attention when Im about to go on a road trip. I know there is a ton of stuff that would make a big difference but I just wanted to share a few ideas I had. Anyone else try anything out or have any ideas they want to throw out there? Next year I will be taking some aerodynamics courses and will gain access to the wind tunnel at school so I will try to test out some ideas on scale models. I hope to come up with results that the average joe can apply to any car to increase gas mileage, and/or performance.
boodlefoof
09-15-2006, 07:58 AM
hotroddr, it looks great!
You wouldn't happen to be going to school at Old Dominion U would you? I think the Langley wind tunnel is about the closest wind-tunnel to me... also the largest in the country from what I understand... but my car isn't that big. ;) I'm hoping to get my Z project in there at some point to try out a few things.
I've recently been looking at under-car air management and throwing around some ideas. I'm still a real novice in the area, but here is a sketch of my most current iteration of the belly pan. I've also tried to start an basic intro-level writeup about the theory behind what I will be doing on the car. Again, I'm a novice. If there are mistakes, let me know!
http://www.geocities.com/boodlefoof/Project_Racer-Zaerodynamics.html
hotroddr
09-20-2006, 10:20 PM
No actually Im at ASU in Phoenix. It may be a party school for most but us engineers didnt get that memo. Im planning on taking a bunch of aerospace classes to further my knowledge in aerodynamics and airplane technology.
I looked at the drawing on that link. Explain to me what some of the strakes are there for. What is your reasoning behind the ones in front of the tires? I would think it would be better to either deflect the air to the side of the tires of down towards the ground to minimize drag from wind hitting the front of the tire.
It looks like you have the right idea for the rear of the car and the strakes to straighten and channel the air under the car. I still have a lot of testing to do with underbody airflow so I dont know for sure. What is the area that is right under where the radiator will be? The vents on the side to help air exit the engine compartment look good. Are you going to put any vents in the hood to allow air from the radiator to exit?
CamaroAJ
09-21-2006, 05:04 PM
so lets say you build a belly pan for your car, with that pan you now have more heat traped in between the pan and floor from the transmission and depending on your design the exhaust. is there a way to vent that heat out without taking away from the pan like adding vents that will act like a vacuum and pull the heat out? maybe Louvred vents? like this only on the bottom of the car
https://static1.pt-content.com/images/pt/2005/06/037-1.jpg
boodlefoof
09-22-2006, 09:59 AM
The area under the radiator is a front diffuser that will put air through the radiator. It will then vent through the hood ala an old GT-40 type of hood nostril. The strakes supposedly help airflow follow a sloping underpan.
As for the design in front of the tires. I can't really take credit. I copied the designs for the most part from race cars shown over at Mulsanne's corner. This type of item seems to be somewhat common, althought my instincts tell me that one would be better off just trying to divert airflow around the tires rather than over them. They obviously know much more than I do on the subject though.
CamaroAJ - I had the same idea. I plan to incorporate some louvres into the undertray.
