ullose2
08-17-2006, 11:14 AM
I know this is a little long but here goes....
I was considering dyno tuning my motor as I have never been to the track, and I dont feel that Im experienced enough to do it by the seat of my pants. I was wondering if I posted the specs of the car if you guys could give me a few pointers as far as tuning goes. I dont have much experience tuning,and this is my first car. The car seems to be running really rich so I will try jetting, and I was also going to try changing the spring combo in the dist. for a little more timing. Is there anything else you guys could recomend to make the most of the dyno time. Is 275/hour a good rate for a chassis dyno? I really, REALLY appreciate your help. Anyways heres the combo.
Engine:
- .030 350 , Scat crank , Eagle rods , JE 10.1 pistons (when we checked the actual compression I think it was 9.85:1)
- Lunati Cam (hyd. lifters) .490/.490 int./exh. lift , 292/297 int./exh. dur. 112 deg. lobe separation
- Holley 20 deg. alum heads 2.02/1.60 int./exh.
-Harlan Sharpe 1.5 roller rocker
-Holley dual plane intake
-Holley 750 double pumper, mechanical feul pump w/ holley regulator pressure is set at 6 psi.
-Flowtech tri-y headers 1 5/8 in. primaries, Flowmaster 40 series mufflers, 2.5 in exhaust
-Ignition MSD Pro-Billet dist. mech advance MSD 6A box Blaster 2 coil 8.5mm super conductor wires
-trans th350 , 2400 rpm stall , Moser 12 bolt 3.42 gear, tru-trac diff.
These are all the specs of the car i could remember off the top of my head. If you need to know anything else I will find out and post. Anyways, thanks again.
Heath
Engine:
Heath
