JEFFTATE
08-15-2006, 09:33 AM
A friend of mine changed the steering box and pump on his 69 Camaro. He used a 3rd gen Iroc box with a replacement pump from NAPA. The original pump had smaller diameter hole in the fitting on the pressure side. The replacement pump had larger diameter hole in the pressure side fitting.
Is this larger diameter hole going to hurt the pressure? Or will it help the pressure by increasing the flow ? Or will it change the pressure or flow or feel at all ?
