Results 1 to 7 of 7
Thread: help choosing brakes
08-10-2006 #1
In the ongoing plan of things to do to my car, I've run into brakes. I'm probably looking at 18inch rims.
Now I have a 71 B-body mopar, and its a big mother. I have been looking through for a brake upgrade. currently my car has drums all the way around, and I have a pretty tight budget.
I've only managed to turn up kits from wilwood and stainless Steel brakes. The willwoods being considerably less money. since I have drum brakes, it means a couple kits from other companies get thrown out the window, seeing as I'm not tracking down b/e body disc spindles anytime soon.
The wilwoods only come in 10.75, 11, and 11.75 diameters, and ssbc isnt much better. the width on both is about .8".
what my question amounts to is basically , is an 11.75" front disc setup enough for a 4000 pound car with 18 inch rims? I'm probably looking at a goal of 350-400 horsepower. and I'll match the rear brakes accordingly.
What would you guys recommend for brakes?
also, given the mass of this thing, am i right in assuming that I wont regret the decision to keep my power brakes? if my car weighed closer to 3000 pounds I'd probably chuck 'em, but what do the experts think?
Thanks!
Dan
08-11-2006 #2Check out AR engineering for the Viper caliper swap. Andy has done some really cool stuff with his early B-body (65). He has you covered and all you have to do is by the calipers. by the way, the caliper are extremely high, even used.
SSBC pissed me off on the Power Tour last year and they sit in the sun for all I care, really ****ty attitude toward mopar. Baer has some stuff for the b-bodies. The spindles and such on your b-body should be the same as my '73 e-body if your have disc brakes now.
Good Luck!
08-11-2006 #3
