View Full Version : Which EFI controller to use?
BigBlockOlds
08-09-2006, 09:21 AM
Just curious on everyone's opinions on what would work for my engine/car setup?
I've been looking at using the Megasquirt V3.0 for a long time but am still a little unsure if it will work as well as some of the more expensive units?
My setup is an '87 Olds Cutlass Supreme that I am currently trying to finish.
Engine: 437cid (.060" over 425) Olds Big Block
Ported cast-iron heads
Hydraulic roller cam
(230/236 dur. @.050, .622"/.625" lift,112* LS)
Offenhauser Super-Sonic intake with fuel injector bungs welded in
1000-1500cfm throttle body
Trans: Stock '96 T-56 6-speed (for now)
Rear: 8.5" 10-bolt with 3.73 gears (for now)
I'm hoping to get the engine in the 500-550HP area naturally aspirated with a possible 100-150HP nitrous shot later on.
Any ideas on what I should be looking at? Driveablity is key for this car! It won't be driven daily but I also don't want to be scared to drive it 500 miles either.
Thanks for the help,
