View Full Version : 4th gen F-body wheels on a 68-72 A-body
payne
08-08-2006, 12:16 PM
Anyone know if a set of 17x9.5 and 17x11 wheels for a LS1 f-body will fit a 68-72 a-body?
-Jason
derekf
08-08-2006, 07:00 PM
They *might* fit with spacers; the offset is way off for them to fit without them.
Not sure you'll fit an 11" wide wheel under an A-body regardless without narrowing the frame rails though.
USAZR1
08-09-2006, 12:13 PM
A 17x9.5 and a 17x11 will fit under a 68-72 Chevelle or El Camino if the backspacing is correct.
KAA
08-09-2006, 09:40 PM
-Jason They'll fit fine. I have them on my '70 El Camino. You'll need 1" wheel adapters with the correct offset wheels. There are different offsets so you have to make sure you get the correct ones. Measure, measure, measure!
AllenW
08-12-2006, 06:22 PM
What bs do you have? Is the car mini tubbed or anything?
Derek69SS
08-12-2006, 06:51 PM
There is 13+" (varies from car-to-car, but usually ranges 13 - 13.25") of space in the rear of a 68-72 A-body, and a 315/35/17 runs about 12.5" wide, so it will fit, but it's damn tight.
Backspace *should* be around 5.5" in front and 6.25 in rear for 9.5 and 11" wheels, but brakes, spindles, etc will have an effect, so measure carefully!
AllenW
08-13-2006, 04:43 PM
What do you usally measure? I have never bought a set of wheels.:rolleyes:
