View Full Version : Return style fuel system
Putting a 2002 LS1 in to a '69 Camaro. I need return style fuel rails. What are you guys using? I found the '97 Corvette return style stock fuel rails for $193 at rockauto and billet rails at Speed Inc. for $139.99. This is a stock engine for now but will be doing modifications soon. I'll be runnig a sumped tank, weldon 600a pump, with a aeromotive reg.
Tia
Denny
ProBell
08-08-2006, 02:12 AM
I used a set of FAST fule rails on my motor. I was told they would work up to 1000 HP. I like the looks of them to, but do not know if they will fit under the stock covers. Did not use any covers on my motor.
Randy
68Formula
08-08-2006, 03:25 AM
The actual rails wouldn't be the issue at 1000HP, it's the injectors.
Just curious but why? With your setup can you not run the later C5 fuel filter/return line filter? It would make life easier and cleaner.
Try some corvette only salvage yards for the early fuel rails. Corvetteforum.com has a classified section and I believe a want section too.
All of the factory regulators are not adjustable. Being that I'm not using a factory or replacement(walbro) pump, I wouldn't be able to get the rail fuel pressure to 58.8 lbs. with the High performance Weldon 600A.
I just ordered a set of pollished billet fuel rails.
Fuelie Fan
08-09-2006, 05:49 PM
Has the weldon been shown to overpower the factory regulator/filter unit?
