View Full Version : Anyone using Procar Rally's W/ Procar adapters...
formula
08-07-2006, 12:32 PM
Did you have trouble with the height of your seats with their adapters? Mine are just sitting way up there...looks like I'm gonna have to mod the adapters to get them down to a driveable height.
ProBell
08-07-2006, 12:53 PM
Yes I did not like how the Pro Car seats sat with the mounting brackets they sent. I not only did not use the adapter brackets, I cut the back mounting tab off the seat rail and bolted through the rail to the floor. I then welded a piece of 1" square stock across the front to bolt the front of the seat to. This droped the Pro Car seat down about 3" from what they sent and about 1" from stock. The seats work great in my car but are showing some wear on the drivers side with only 4000 milers on the seat.
Let me know if you need more info Randy
Ragtop68rs
08-07-2006, 05:17 PM
I had the same prolem. I ended up shortening the brackets by about an inch. I also cut the bottom two mounting positions off the bottom of the seat and used the last one closest to the seat. They now sit about the same as stock. I have only had mine about a month but so far I like them. John
formula
08-07-2006, 08:51 PM
I bet that's what I'm gonna have to do. I can't bolt mine straight to the floor because of the funky floorpan shape on a second gen...wish I could though. I need the headroom!
