DLinson
08-04-2006, 02:12 PM
If you haven't read my other thread on my cooling problems, I found a crack in my engine block between the #7 cylinder and the lifter bore. Now I am in search of a new engine block.
I have found two blocks, which one would you choose?
Block #1:
454
2 bolt mains
stock bore maybe .030 over
everything else is stock
cost $450
Block #2
454
4 bolt mains
mains use studs instead of bolts
.060 over
several head bolt threads are stripped and need to drill out all of the head bolts, tap out to 9/16-12 threads and install threadded inserts.
cost $100 for the block, $60 in inserts, and a saturday of my time to install inserts.
I am going to use all of the 427 parts from my current engine including the .070 over pistons, roller cam, timing chain, aluminum heads, etc. Either block will need to be bored out anyway. I'm leaning towards block #2.
What do you guys think?
Dennis
Block #1:
454
2 bolt mains
cost $450
Block #2
454
4 bolt mains
.060 over
Dennis
