View Full Version : need some good alignment specs
my suspension is stock except for eibach lowering springs, good bushings, and a good sway bar. this is a temporary set up to get the car driving. my question is whats are some good alignment specs for the best handling possible for this set up. the car will be drven often so tire wear is some what of a concern. keep in mind the car does not have the guld strand mod.
dennis68
11-01-2004, 10:59 AM
Run .5* neg camber and as much caster as you can get out of it. Set toe-in to 1/8" total toe. That will give you a nice street set-up without any tire sacrafice. You may want to think about running the "g" mod at least, it's free.
thanks dennis, yeah this is only the begining, im experiancing alot of a pressure to get this thing on the road. alot more suspension stuff is in the works like i said this is only temporary i just want to get the drive train broken in before it snows!
