View Full Version : Which Years LS1 Rear Brakes Fit a First Gen Camaro
Joe_Rocket
11-01-2004, 12:13 AM
I've seen the articles on 93-97 rear disks, but how about 98 and up? Can these fit as well?
MuscleRodz
11-01-2004, 10:24 AM
yes here is a tech article.
http://members.fbody.com/86firebird/ls1/ls1brakes.htm
Mike
MuscleRodz
11-01-2004, 10:29 AM
Forgot to add this is for a third gen but should apply to your first gen. Also you will need to run two right side caliper brackets unless you have moved the shocks I believe. Ebrake setup is different as well. Hopefully someone else will chime in and finish filling in the blanks.
Mike
68BNUT
11-01-2004, 11:12 AM
you can use 98 or newer but then you still have the drum style e-brake, I didnt really like that set up so I went with 97 and older the set I used came with the e-brake cables and I got them to work with a little braket fabbing on a 68 camaro
Joe_Rocket
11-01-2004, 12:56 PM
OK, thanks, guys.
I will probably go with whatever I happen to find first, unless there is any issues with the newer style and the mini drum e-brake.
My wife and I spent yesterday morning at the Junk Yard pulling out an 8.5 10 bolt housing from a 73 Nova. I couldn't find a 12 bolt and I'm going the low buck route until we have a bigger garage and I can fab the mounts for something more trick, like an IRS.
It's nice to have a wife that will get her hands dirty turn the wrenches with ya!
68BNUT
11-01-2004, 02:54 PM
I got my rear brakes from a salvage in florida on e-bay went to there website and they were 25$ cheaper If I can find the name Ill post it in here It was 225 with shipping to Dallas Included everything bolts brackets, cables, and lines
68RallySport
11-02-2004, 11:55 AM
hell id love that website to please....
68BNUT
11-03-2004, 08:34 AM
Here is that web page sorry it took so long It wouldnt ever come up in the search now I know why there site was down. The kit I bought was the 150$ 97 and older set. I did buy new rotors for it at auto zone just so they were new looking.
http://www.tacreationsusa.com/suspensi.htm
rwhite_692
11-03-2004, 10:12 AM
I have installed LS1 (LS1 is 98-up F-Body) Rear discs on a 69 camaro. The fab work was mostly simple, to modify the driver's side backing plate/caliper mount to put the driver's side caliper forward of the rear axle.
Photos at the link below
