paul67
07-29-2006, 03:52 AM
On having my car tested , when the rear suspension was raised with the wheels off the floor ,found that the rear hubs move up and in when checking for wheel bearing play, is this normal , if not what would be the problem as the tester said it's poss that its set like this and when the car is lowered the play is taken up , the play seems to be with the drive shafts moving in and out in the diff when not under load :hmm: .
