View Full Version : 335x35x17
ididit
07-26-2006, 04:43 AM
can they be mounted on a 11 in wheel??
cykotic
07-26-2006, 10:16 AM
Not sure, but I believe you need at least a 12 or 13.
ididit
07-27-2006, 03:39 AM
thanx.. but I was told you could get by with a 11..
B Schein
07-27-2006, 04:00 AM
They will work on an 11 inch wheel. In my opinion 12s are the best size for a 335 13s are to wide and make the tire look goofy.
bretcopsey
07-27-2006, 04:17 AM
Go to www.tirerack.com (http://www.tirerack.com) and view the spec on that size. They list the 'allowable' rim widths as well as the width of the rim that was used to provide all of the other stats such as tread width etc. since those dim's change with different width wheels.
Typically 11"-13" wide wheel is acceptable for 335/17. Step up to 335/18 and the minimum wheel width goes to 12" :pat:
ididit2
07-27-2006, 06:13 AM
thanx everyone......
