View Full Version : how to lower my 65
lt1chevelle
07-25-2006, 08:51 AM
what is the best way to lower my 65 chevelle. i hear alot of people talking about b-body spindles but iam trying to do it on limmited funds so please give me any feedback that would help me.iam looking to lower the car 3 to 3-1/2in in the front. and i figuered ill just use drop coild in the back.
PT Goat
07-25-2006, 10:42 AM
3-3.5 inches is a BIG drop on an A-body, nothing I'd want to drive on the street. I just installed Eibach springs, and although my motor is still on the stand, a 1.5-2" drop is quite noticeable.
Now the front of the A-bodies does tend to sit higher than the back from the factory, so a little more drop to the front might be in order. If you want to go real low, and level the front out, you could install drop spindles up front and lowering springs all around (cut yours, Eibach, Hotchkis, or custom). I'm not a big fan of the 2" drop spindles, at least those I've seen on Camaros...too low for my taste. I had one friend remove them because the car was just too low to drive.
The other thing you could do to get the lowered look is install thinner body mounts, which would lower the body on the frame just a little. I know I've seen them somewhere, maybe eBay? That would give you a slightly lower look without compromising ride height.
Derek69SS
07-25-2006, 11:58 AM
What size front tires will you be running? The tire to inner-fender clearance will be the limiting factor, unless you have very low hanging exhaust.
If you decide to go with drop spindles, Heidts makes the best one for a Chevelle, since it also adds 1.5" to the height of the spindle, putting the camber curve in a more favorable position.
lt1chevelle
07-25-2006, 12:43 PM
in the front i was looking to run a 235-45 or 40-17 or maybe even a 245. and out back a 275-45or40-17 (fender lips are rolled) should i get the car lowered then order the rims or order rims then lower the car to the hight i want?
also i went to the site and they dont have any thing for chevelles its camaros,55-57 chevy and novas,classic trucks and mustangs didnt see anything for chevelle
Derek69SS
07-25-2006, 01:45 PM
I'd get the wheels first, but you'll want to know for sure what spindle you're going to use before you order the wheels, since some spindles change the track-width.
Check in the Wheels & Tires section at Team Chevelle to find out what backspacing you'll need for a '65. I think a 275 is as wide as you can go in the rear, but you may be able to get more than a 245 in front.
If you want to play in the "very low" range, you may want to go with the 5"x9.5" dirt-track springs with height adjusters, so that you don't have to order springs more than once to get it "right".
lt1chevelle
07-25-2006, 02:18 PM
alright ya i think iam going to keep the spindles i have and just get lowering springs thanks for your help
lt1chevelle
08-04-2006, 06:27 PM
well once aganing i have changed my mide i went the the qa1 coil-overs for the front and the back of my car sence they dont make any good drop spindles for chevelles i guss we will see how this works out
