rockdogz
07-22-2006, 08:43 PM
I just ran into a problem today at the end of a 50 mile trip. It was HOT here today, not sure if that contributed to the problem...
About 2 miles from home, I noticed that the brakes were partially applied - all the time. The pedal was super high and hard. I made it home and the engine was hot from having to fight the brakes, and the rotors looked kindof bluish from being so hot. Once it cooled down for 5 minutes then the pedal was fine again.
I came across a post on lateral-g from Mecom Racer who had the same problem, and the fix for him was to shim the master cylinder some. I can try the same thing - actually I have an adjustable brake pedal pushrod, but I'm curious what the cause of this is - and if I do indeed have the same condition since I have manual brakes. Do I need to try to bleed the brakes again - could an air pocket have caused this?
My setup is 4 wheel Wilwood dynalites 4 pistons, with an aftermarket plastic master cylinder - I think it's from a Corvette. I don't remember the bore size right off but I can look it up. Any comments appreciated :twothumbs.
