View Full Version : 67 Camaro Radiator Sizes (Dimensions)
TheRoaringEagle
10-30-2004, 02:02 PM
What're the dimensions of a 67 Camaro radiator? I don't have my car right now and I want to order the radiator now through Summit. I have a 400 SBC and a TH350.
I wouldn't mind a stock size but I would like a larger one even if the core support hole is smaller than the radiator. What's the largest radiator anyone has put into their first gen Camaro? Thanks
JMitch19
10-31-2004, 10:58 PM
I had a BeCool in my 67 rs. It was 26 X 19 which I believe is the same size as the stocker.
Kenova
11-01-2004, 09:01 AM
I used a Summit universal alum. rad in my '71 Nova. The core measures 23"x19". It took a bit of modifying to make it fit, but it was cheap enough that I think it was worth the effort.
I'm also using a repop rad support. The rad opening is the same size as the big block SS Novas and the rad core is the perfect size for the opening.
Ken
porschev8
11-08-2004, 06:08 PM
I know if you remove the core support braces you can fit a 31" x 19" radiator.
