View Full Version : Engine Position-Tech Help Needed
Patrick
07-22-2006, 06:26 AM
I have purchased both the S&P LS1 Engine Plates and the Holley LS1 Swap Plates to compare.
Here is what I found: Compared to the S&P Plates, the Holley Plates move the engine back(closer to the firewall) by almost 1.25". However, the Holley Plates RAISE the engine by about 7/16".
So the question is..When building a car for handling what is better:
Engine forward but lower?
or
Engine back but higher?
paul67
07-22-2006, 07:13 AM
back, the further the engine is to the centre the better also lower if poss
Patrick
07-22-2006, 09:29 AM
I agree..however with the plates I have, I dont have the option of back and lower. So given the numbers above, which is the better of the two?
Matt@RFR
07-22-2006, 10:08 AM
1 1/4" engine setback won't make a damn bit of difference. I would opt for stock longitudinal location and down some.
andrewb70
07-22-2006, 10:25 AM
I would think that 1 1/4 inches would make a difference considering your moving the transmission back the same distance.
Ron S
07-22-2006, 10:48 AM
You may want to check header clearance before you make a desicion.That was the problem I found.Some mounts aren't real generous with steering box and frame clearance
Patrick
07-22-2006, 11:33 AM
I am using the Holley/Hooker Long Tube LS1 headers which clear with either set of plates, however they are really tight with the S&P mounts (I had to demple one tube to clear the pitman arm). Clearance with the Holley Plates is not an issue.
I am just trying to determine which set offers better overall weight distribution.
paul67
07-23-2006, 12:10 AM
The plates that move the engine back.
jannes_z-28
07-23-2006, 12:19 AM
In the installation guide for LS1 engines that GM sells (#88959384) they have a drawing showing how the engine mounts should be located to get the backplane at the same location as an CSB engine.
From seeing pictures of the Hooker plates I believe that they have done them according to the GM spec.
The S&P plates are done the "easy" way and using one existing bolthole in the block and therefore moves the engine/trans forward.
Jan
ProStreet R/T
07-23-2006, 03:19 AM
In the terms of overall effect keep it LOWER.
When you look at the change in weight distribution by moving the engine back 1 1/2" it doesn't do a damn thing. By comparison moving the battery to the trunk has a far more profound change in weight balance. To see any major benefit you need to move the engine 6-8" rearward.
nitrovette
07-26-2006, 09:31 AM
The plates i got for the vette put my motor 1 1/4 inch forward,so i had to move my 700 forward and remake the crossmember.The thing was i modified my hooker sidepipes to fit ls1 flanges ,when finished the sidepipes came out right in the right location,if i had set the motor back the 1 1/4 inch they wouldve been jambed up against my rear tires,so it helped me by using them.
Patrick
11-25-2006, 01:28 PM
FWIW,
I welded up the Holley plates. Then drilled and tapped them to sit lower but in their original position (closer to the firewall).
I ended up with plates that position the motor tight to the firewall (Holley's position) and Lower (S&P's position).
The headers now have plenty of clearance.
