View Full Version : steering problems, 3rd gen box into '67.
67RScamaroVette
07-18-2006, 09:26 PM
I just installed my newly rebuilt turdgen box in my Camaro, after rebuilding it, painting it, torquing my steering arm nut to 200 ft/lbs swimming in red loctite (oh no, you might say.) Yup! Problem here. check it out.. anyone know a solution that doesnt involve me pulling out the pipe wrench again?
https://static1.pt-content.com/images/pt/2006/07/steeringprobsyo-1.jpg
top one's my steering arm. I'm not swapping steering boxes, this thing kicks butt. gonna party, er, steer, like it's 1992.
any help appreciated.
olly
07-18-2006, 10:24 PM
ahh ummm I thought the pitman arm had the ball joint? WTH? https://static1.pt-content.com/images/pt/2006/07/67manstrlong-1.jpg
Looks to be the wrong pitman, pull it fast!! You can rent puller from Kragen. Or bring it to a front end shop with a sixer.
Tom Welch
07-19-2006, 05:36 PM
yep, use the pittman arm for the car you are building, not the one for the car the box is made for. It will work.
BonzoHansen
07-19-2006, 07:07 PM
Yes, that appears to be a 3rd gen arm - I just threw one in the big box of useless parts. The 2nd gen arm is flat and the 1st is wearable.
smeshey
07-27-2006, 02:20 PM
well did you get it straightened out more pics when it is fixed thanks Scott
07-27-2006, 06:18 PM
The pitman nut torque spec is 145 ft lbs.
If you have any mis alignment of the center link, loosen the idler arm and steering box bolts at the frame, then connect the center link.
67RScamaroVette
07-27-2006, 08:16 PM
I haven't got the new parts, yet.. I'll update when I do.
Steve68
07-28-2006, 03:17 AM
You ever get the PM about the rotors on ls1 board??
67RScamaroVette
07-28-2006, 05:47 PM
yeah, I got it. I dont have 160 bucks to blow right now, and my 12" ones will do just fine. In a sub 3000lb car that wont be auto-x'ed, 12" dual pistons are plenty. I gotta conserve money, i'm saving for a DD.
how's your car coming?
olly
Steve68
07-29-2006, 09:53 AM
Whats a DD, less than 3k, you need to go find a scale, if you gonna be less than 3K you need to take the car back apart and start cutting,
waiting on money and parts,
