View Full Version : Howto torque cylinder head?
elcamino80
07-17-2006, 11:51 AM
Ok so this is probably a total "n00b" question but here it comes:
How should I torque my stock cylinder heads on my '89 350TBI engine? Is there a certain pattern and to what torque should i tighten them?
All knowledge and experience is welcome
6'9"Witha69
07-17-2006, 12:02 PM
There is a specific order, but it follows the "start from the middle and work your way out principle". About any service manual has it in there for an SBC. If I had access to a scanner I could do it for you.
justanova
07-17-2006, 02:15 PM
http://www.small-block-chevy.com/assemblyspec.html
its about half way down the page
harshman
07-17-2006, 02:51 PM
how 'bout BBC? i couldn't find any specs on the web.
Lowend
07-17-2006, 04:42 PM
https://static1.pt-content.com/images/pt/2006/07/headtorq-1.jpg
Small block
elcamino80
07-17-2006, 09:42 PM
Thanks guys!
justanova
07-18-2006, 06:27 AM
http://members.tripod.com/torquespecs/hi_po_chev.htm
try this
harshman
07-18-2006, 04:05 PM
Now that I know how to torque them on, how do I get them off in the first place. I took all bolts off, and attempted to lift the heads off by inserting a wrench into the water ports and heaving ho but nada.
justanova
07-19-2006, 06:46 AM
I would double check to make sure you have all the bolts out, its kinda easy to miss one. then maybe stick a longer prybar in the water ports and heave ho.
I see you live in prescott valley, do you ever go to the dirt track races up there?
6'9"Witha69
07-19-2006, 07:43 AM
Take a mallot and give the head a few smacks on the face. Then use a prybar in an exhaust port. S/B easy from there. It also depends on the gasket quality. Crappy gaskets stick everything together really bad. I always suggest at least the Fel-Pro blue stripe gaskets.
harshman
07-19-2006, 08:21 AM
not yet. i'd liketo some day, i just haven't had the time.
justanova
07-21-2006, 01:42 PM
have you been able to get your heads off? if the prybar in the port dont work I have had to gently tap a screwdriver between the head and block to get the head to loosen up, just be careful not to gouge the deck.
If you ever get out to the track I pit for the 007 modified, we will be there sat night to see if we can put a win on the board.
