View Full Version : have 12 bolt need brakes 72 chevelle wagon
autorand
10-28-2004, 08:09 PM
15in. wheel. looking at late s-10 blazer rear disc looks like all most a direct fit the axel could be turned down to fit the rotor how do i deal with drum type (E) brake cable
73novaguy
10-28-2004, 08:47 PM
I put a moser 12 bolt in the Nova a month or two ago and Wilwood had a disc brake setup for around 500 or so I think??? It was a 12.19 inch rotor and 4 piston billet caliper. Fits inside of my 15" Weld Pro Stars, clears by about 1/16th" to an 1/8th". The 12 bolt I ordered was a pressed in (do I dare to say it) "Ford style" bearing. But I am sure if you called Wilwood they have a regular kit for the standard 12 bolt.
Zefhix
10-28-2004, 11:29 PM
Hey, the rear disc setup (you need everything minus ebrake) from a 98-02 Camaro/Firebird LS1 car will bolt right up!!
strangler
09-29-2005, 06:19 AM
Anyone hooked up their stock pedal to LS camaro e-brake?
