    Results 1 to 9 of 9
      Apr 2004
      OKC, OK
      Very flexible sanding boards. Where to find?
      I need a very flexible sanding board like what you might use on an old street rod fender. I have seen some advertised where they use rods to adjust the firmness of the board but I can't find where to buy one. My local paint store doesn't carry anything like I am looking for either. Any ideas?
      Mike
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Nov 2004
      Eastern Washington
      Can you make your own? I went to Jo-Ann Fabrics and bought some of the 3 or 4 inch thick foam. I cut it into strips and wrapped the sand paper strips around it. It can be rather flemsy if you cut it too thin though. I glued a strip of cardboard to the top of it and that seemed to help a little.
      Apr 2004
      OKC, OK
      I can but right now I would rather buy one and be done with it. It I can't find what I need by the weekend i will probably make one.
      Mike
      Mike Redpath
      405-288-0189
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Nov 2004
      Eastern Washington
      You might want to try this place
      http://www.leopardsystems.com/paintucationforum/
      They have LOTS of knowledgeable body/paint guys who might know.
      Feb 2003
      St. Louis, Missouri
      Apr 2004
      OKC, OK
      Thanks Happy! I knew I seen them somewhere.
      Mike
      Mike Redpath
      405-288-0189
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Feb 2003
      St. Louis, Missouri
      No sweat.
      Michigan
      www.adjustflexsand.com
      Eastwood sells this same brand but the originator has more sizes available. I will tell you that the 36" block with 40 grit will kick your butt. I've been using them about two years. If I could only buy one I would get the 21". Seems to be my favorite unless I'm blocking a big surface.
      The AFS boards are definately the way to go, I agree the 21" board is the most useful, but if you are doing big flat panels the 36" is a must....
      Try www.route66supply.com the prices are alittle cheaper than the manufacture $59 instead of $70
