View Full Version : AFX spindles and GW A-arms. Grind bumpsops off?
Whistler
07-11-2006, 09:42 PM
My front suspension has AFX tall spindles, GW upper and lowers, and QA1s. I have crap for turning radius. My tires don't even come close to the tire-clearance notches I cut into the frame rails to get full lock with the old suspension.
At a quick glance, it looks like the steering bumpstops are going to have to come completely off. Anyone else run into this?
zbugger
07-11-2006, 09:55 PM
Is it touching the bump stops? How is the turning radius compared to stock? How wide are your tires?
chicane67
07-11-2006, 09:58 PM
I think you mean steering stops.......
As of yet, I am not aware of this. You are the first to mention this issue......
What is you wheel width, wheel offset and tire size ?? Did you switch from a drum front brake set-up or was it a factory disc chassis ??
Whistler
07-12-2006, 05:01 AM
Yeah, I meant steering bump stops....it was late last night :)
I'm running 18x8.5s with a 265/35/18 and 5.5 BS.
It is a factory SS disc chassis. I'll post up some pics later.
baz67
07-12-2006, 07:36 AM
I'm running 18x.5s with a 265/35/18 and 5.5 BS.
There is your problem. It has nothing to do with the control arms or spindle. I bet your outer tie rod is real close to the rim as well. You will need to put a spacer to push the rim out a little.
Whistler
07-12-2006, 08:30 AM
No, the steering bump stops are what is limiting the movement. The rims come close to the tie rods, but don't touch. About 1/4 inch clearance.
baz67
07-12-2006, 10:09 AM
Try putting the stock lowers back on and see if the problem is still there.
zbugger
07-12-2006, 11:24 AM
How wide is the wheel again? I missed it. All I see is 18 x .5 there. The backspace will be the issue. Last I heard the MOST you could get on there without any issues was 4.75"-5" backspace on a first gen. The 5.5" backspace is most likely the issue here.
4MuscleMachines
01-11-2007, 02:52 PM
I had GW uppers and lowers put onto my 69. I also have the ATS spindles and the turning radius is very bad. It is a PITA just manuvering around a bit. Much worse than the rack that was previously on the car.
Whistler, did you find the remedy?
DarkoNova
01-11-2007, 03:32 PM
This isn't reassuring my decision to buy the spindles...
Matt
6'9"Witha69
01-11-2007, 03:40 PM
MattThe spindles don't have the steering stops, the LCAs do. GW stops protrude more than stock so that those with wider front wheels/tires don't rub the frame.
Speedtech LCAs have adjustable stops on them.
DarkoNova
01-11-2007, 05:07 PM
Oh, well I'm going to be using the stock lowers anyway. No worries, then. :)
Matt
4MuscleMachines
01-11-2007, 09:29 PM
Matt
69w/a 69 is right. I will have the stops ground off the lower arms and see what happens.
IMO, the AFX spindle is the only way to go and has no contributing factor in a bad turning radius.
Whistler
01-21-2007, 01:24 PM
Sorry, I haven't been here in a while. Yes, I just ground down the stops until I got the radius I wanted. I also notched the frame in the back of the control arm to allow a full lock with an 18x8.5 with 5.5 BS
