    Results 1 to 4 of 4
      NJ
      Brake adapter fittings
      I was looking to run braided line from my master cylinder to the distribution block down on the frame.
      I am looking for some AN fittings that I can use to adapt from those ports on the MC and distribution block. I've looked at Russell, but they only go as large as a 7/16 inverted flare, but the ports are larger than that.
      Does anyone know of where I can find fittings like this?
      You might be asking whay I want to do this, but I think it would be easier than buying and flaring Stainless tubing.
      Thanks for any info you guys may have!
      Delaware, OH
      If you haven't already, you should give InlineTube and ClassicTube a call. They both sell a decent selection of NPT, AN, inverted flare and banjo fittings as well as the associated hoses, metering and distribution blocks.
      http://www.inlinetube.com
      http://www.classictube.com
      Got that 572 humming yet? I just fired mine for the first time last weekend.
      NJ
      yo dan, thanks for the sites, I'll check them out
      Hows your project going? Tell me what its like!!!! I cant wait to get mine done! Is it really just useless, endless amounts of torque like they say?
      Delaware, OH
      Well funny you should ask Jon! I took the 572 out for her maiden voyage on Monday. Before I ever got out of 1st I could tell there was something wrong with the carb. The engine idles fine (nice and lumpy) and when applying throttle it runs like a scalded cat (MUCHO torque!), but the carb won't "cruise". I don't care if it's 15mph in 1st or 65mph in 5th, when holding the throttle in one position, the carb surges and stumbles horribly. I've called BG a couple times and received different diagnosis each time. I think the Demon has a manufacturing defect.
      So tomorrow I'm installing a 930cfm Holley I have on the shelf to see if things improve (I expect they will). Luckily you won't have to deal with the carb! - lol - If the Holley runs out smooth then I'm returning the Demon under warranty for a replacement.
      The motor has GOBS of torque!! I'm running a TKO and 3.42 gear and have NO problem breaking the tires loose at 65mph in 3rd. It's twice the motor of my old LS-7 454! So with the carb I'm not so pleased, but with the engine itself I couldn't be happier.
