View Full Version : 67-69 camaro subframe
paul67
06-30-2006, 05:44 AM
Can someone please tell me the distance centres between the upper control arms ie left to right and the distance between lower control arms ie left to right, and also the distance between the upper to lower control arm mounts centres please.
thanks paul
06-30-2006, 06:05 PM
answer might take a bit..its a big weekend for us yanks. I 'll try tomorrow.
paul67
07-01-2006, 05:47 AM
Cruiser
07-01-2006, 10:38 AM
This could be a real long shot here but have you ever been to or lived in San Diego Ca.....Paul? I ask because I knew a gent name Paul from England, he moved back many years ago. Had to ask you never know.
Joe
Camaro Zach
07-01-2006, 03:46 PM
Well there are a ton of variables with this so i'd get a few different people's measurements. Also im not sure how to measure the distance from the UCA to the LCA pivot centerline without doing some sort of 3d model. I'ts just difficult to measure with only a tape.
UCA mount to mount - 30.5"
head of bolts on front of LCA - 24.75" center to center
end of bolt on rear of LCA - 18.25" center to center
paul67
07-02-2006, 09:39 AM
thanks im making a 3d model in wood and tube to see what rack can be fitted with no bumpsteer as i have had to alter the upper and lower control arms for the 96 vette up rights, as they are not the same as 84 uprights.
