View Full Version : Really basic caster, camber, toe clarification
Tudorwagon
06-28-2006, 01:57 PM
Before I start in on doing some alignment work (see my other thread) I thought I'd better get absolutely clear on caster, camber and toe. I did a search but didn't find much info which clearly defined each setting in layman's terms. Correct me if I'm wrong on the following:
Negative caster = the top of the line intersecting the upper and lower ball joints is in front of the bottom of the same line
Positive caster = the top of the line intersecting the upper and lower ball joints is behind of the bottom of the same line
Negative camber = the top of the tire leans in farther than the bottom of the tire
Positive camber = the top of the tire leans out farther than the bottom of the tire
(These are pretty obvious but I figure I should cover all three settings)
Toe-in = the front of the tires are closer together than the rear of the tires
Toe-out = the front of the tires are farther apart than the rear of the tires
TIA
DusterRT
06-28-2006, 02:21 PM
Yes. I think I get what you're saying at least. With positive caster, the top of the line passing through the UBJ/LBJ would lean towards the middle of the car; negative towards the front. You're right with everything else. Let us know how the home alignment stuff works out, I've been looking at that myself for a while..at $65 a pop, it can get expensive if you change things even infrequently!!
Tudorwagon
06-28-2006, 07:44 PM
You know, I typed the caster stuff about three times and I think I had it right the first time. I thought about it too much! So, the correct info is:
Negative caster = the top of the line intersecting the upper and lower ball joints is behind of the bottom of the same line
Positive caster = the top of the line intersecting the upper and lower ball joints is in front of the bottom of the same line
DusterRT
06-28-2006, 07:56 PM
Let's see if this works: "/" is the imaginary line passing through the ball joints in the front end of a vehicle.
<front of car> [ / ] <rear of car>
^^^^ This would represent positive caster. ^^^^
<front of car> [ \ ] <rear of car>
^^^^ This would represent negative caster. ^^^^
<front of car> [ | ] <rear of car>
^^^^ This would represent zero caster. ^^^^
Tudorwagon
06-29-2006, 05:15 AM
Then I had it right in the first post. Sorry I didn't make it more clear what I was saying, it sounded good in my head!
Thanks.
DusterRT
06-29-2006, 06:42 AM
No problem..sometimes things are just hard to convey clearly over the keyboard!
06-29-2006, 07:50 AM
Here are some links
ALIGNMENT HOW TO
http://www.heidts.com/heisinfo.htm
http://www.carcraft.com/editorial/mgarcia_article.jsp?viewtype=text&id=24880
http://www.shallowsky.com/alignment.html
http://www.vtr.org/maintain/diy-alignment.html
http://www.monte-list.nu/tech/boxmesh.shtml STEERING BOX ADJUSTMENT- MANUAL
http://jeffd.50megs.com/Pump_valve_mod_page.htm POWER STEERING VALVES
http://www.ifsja.org/tech/steering/boxadj.shtml STEERING ADJ SAGINAW POWER
http://www.chevyhiperformance.com ARTICLE ARCHIVES ON SUSPENSION
http://www.musclecar-usa.com/carsetup.shtml SUSPENSION TUNING CHARTS
Tudorwagon
06-29-2006, 08:47 AM
Thanks for the links David. The Car Craft and VTR links are no longer working (at least they didn't work for me).
