View Full Version : ford 9 inch disk brakes?
2lofosho
06-21-2006, 05:35 PM
does anyone know where i can get a disk brake kit for a big bearing 9 inch with a 5x5 bolt pattern. i have searched the net to no avail. every kit i find is for 5x5.5 bolt pattern if it helps the rear end is from a 66 lincoln continental but it is a big bearing 9 inch ford. thanks in advance
Siroadrnr
06-21-2006, 06:07 PM
I got one years ago from J&J Race cars, not sure if they have a web site, i will try to dig up info for you. Rudy
Tom Welch
06-21-2006, 06:53 PM
Try looking on ebay for Steeltech. They sell a kit for just such an application. I found it by looking for rear disc brakes. I need a similar kit for the 65 T-bird 9 inch that is under my 67 Firebird.
2lofosho
06-22-2006, 10:44 AM
yea i found those steeltech brake kits not to bad of a price. i talked to the guys at rad ride by troy trapanier <sp?> and they said i could run 95 imapla sindels which would give me a few more options for the front. all i would have to do is taper the spindel to match the ball joint on the linc.
hot66
06-22-2006, 07:04 PM
Why not just redrill the rotors on one of the setups you can find easy enough for the big bearing ends? That would be pretty easy with a drill press and a bolt circle template.
Jeff
Steve1968LS2
06-22-2006, 08:08 PM
Wilwood makes an adaptor for that.. as does Baer.. :)
2lofosho
06-22-2006, 08:45 PM
hmmn i guess i will have to look agian i didnt see one for wilwood and i dont remember check baer thatnks for all the help will let yall know what i find
