View Full Version : Which rotor and MC to use with LS1 calipers
ILLEGAL69
10-25-2004, 02:44 PM
I am setting up a CBB kit for my 69 F-body. I have drum spindles/hub, LS1 calipers and a hydroboost unit that accepts a deep style MC. I will be fabricating my own bracket to mount the calipers.
I have 2 questions;
1. What 13" rotor can I use? (I wanted a aftermarket drilled and slotted set)
2. What MC can I use? ( I want to use a newer type, maybe from a 99 Camaro?)
Thanks for all the help, If it wasnt for this forum my car would be bland and boring.
rwhite_692
11-03-2004, 03:27 PM
Front rotor- use the C4 rotor, the C5 is thicker.
You can figure all this out by looking here:
http://www.speedtech-performance.com/Brakes/C5%20brakes.php
I highly recommend the speedtech brackets, its a better solution than a flat bracket and spacer arrangement, and one of the least expensive parts of doing the conversion. Buy a pair and you won't regret the expense for a second.
Some photos of my C5 conversion at the link below.
rwhite_692
11-03-2004, 03:29 PM
Almost forgot- You are on the right track with the master cylinder choice. 98-up F-body w/4wheel discs. I picked mine up on ebay for $23.
