View Full Version : How much does a Dana60 weigh?
Steve1968LS2
06-14-2006, 02:51 PM
Compared to a Ford nine-inch? Trying to figure out how much weight I will save.
Is there a way to decode a Dana60 to see what it's out of? I know some of them are worth a few bucks..
<-- Dana60 illiterate lol
slowcamaro
06-14-2006, 03:08 PM
I dont know danas either but a quick google found this.
http://www.autohobbydigest.com/dana.html
Steve1968LS2
06-14-2006, 03:11 PM
Thanks.. you're better at Google than I am.. :)
Now I have to figure out what I have.. here is a pic:
http://www.z069.us/68/exterior/web_a8.jpg
muthstryker
06-14-2006, 05:17 PM
you dont know what you have?! lol how is a dana60 better then a 9" or is a 9" the best for a heavy car?
Steve1968LS2
06-14-2006, 07:40 PM
I don't know if it's a car Dana60 or a truck Dana60.. I need to get the codes off the housing.
I just know it's a Dana60 with 4.56 gears and Moser axles :)
A Dana60 is WAY stronger than a Ford 9".. which is why they were stuffed behind Hemis and are used in rock crawlers.. but they weigh a ton..
ProdigyCustoms
06-15-2006, 01:06 AM
Steve, I have always heard 60 lbs difference.
Ron S
06-15-2006, 03:51 AM
I've narrowed alot of danas and 9" rears through the years.the dana is definitley the strongest,and heaviest.A car rear is about 50-60 lbs more then a 9".Some of the truck housings are crazy heavy,did one for ls1nova I think that thing had to be 150 lbs heavier,[but his car does hook].Bill of material # is right on the tube,call reider racing they will tell you what it is out of
Steve1968LS2
06-15-2006, 08:25 AM
Thanks.. and thanks to Frank as well :)
I need to get the numbers and run it through.. I was told it has 4.56 gears and Moser axles.. we shall see when I pull the cover.
It's a great rear-end, but I am going another route.. and it's a secret :ssst:
If I save 60lbs off the back then I will that much closer to 3000lbs..
Ron S
06-15-2006, 02:31 PM
Sometimes I like extra weight is a good thing ,if its in the right place and it means I'm not replacing ring and pinions in it all the time .Secret?I'm getting ready to do a 8.8 mustang rear for a heavy big block Nova,Ive been trying to talk the guy out of it,but if the customer doesn't mind replacing parts regularly who am I to say? lol.I have to say that 68 camaro of yours is one of my favorite on the site.My 68 is in the blown apart stage,every time I check out pics of yours I go out and work on mine
baz67
06-29-2006, 10:52 AM
Mmmmm extra 60lb unsprung mass. That is great. I say leave it alone Steve:jump:
Steve1968LS2
06-29-2006, 11:47 AM
Frank (the owner of Strange Eng) said it's more like 30-40.. sure lookes heavier.. lol
And the Dana is bye-bye.. the new system is going to be SO much sweeter.. :Alchy:
cykotic
06-29-2006, 12:14 PM
I wouldn't go so far as to say that. A dana does have a bigger ring gear, but if you compare it to a 9 inch, it's not as thick and the pinion shaft isn't either. I could've swore I saw a comparison in PHR a long time ago too. I'd stick with a 9".
