View Full Version : DSE Quadra-Link
aonghus
06-11-2006, 12:33 PM
The DSE instructions are a bit vauge in certain areas, I'm stumped right now with the installation of the upper-link pockets.
The instructions say "drill two rows of 5/16" on the outboard flange of the pocket in line with the frame rail"
The frame rails as we know in First Gen Camaros are U shaped, with no backing on the top of the rail. Do they mean drill & plug-weld the holes below where the pocket has a "F" stamped in it, in line with the frame rail flange that comes out from the sides?
In the garage, someone bail me out of this, I've only got a certain amount of time I can make all this noise! otherwise have to wait til DSE is open tommarrow...
if someone needs pics to better understand chime in
VenturaII
06-11-2006, 02:23 PM
I drilled two rows of holes through the pocket flange that lined up with where the frame is welded to the floorboard. They are just trying to attach to the strongest part of the flooring which would naturally be where the frame contacts.
Whistler
06-11-2006, 03:05 PM
The frame rail is 'U' shaped, but it has flanges on the top of each side where it is spot welded to the floorpan.. You're just trying to get a few welds to grab onto the inner part of the frame rail.
restomodbird69
06-11-2006, 04:11 PM
here is a pic of mine i only drilled a few holes but i also welded them all the way around the edges to be safe.
Hello, I am getting ready to do the DSE mini tubs and Quadra-link on my 69 Z as well. Curious how long they take to install.
aonghus
06-11-2006, 05:57 PM
tubs are supposed to take in the neighborhood of 40 hours, the quadra-link so far isnt take me much time at all, i've got maybe 5 hours into it, and with your guys' advice, the upper link pockets are almost done!
one question though, did you guys have to do much 'forming' of the floor pan to the bottom of the bracket? i've got probobly 1/4" of an inch of space on the inside flange that i'm working to remove...
thanks a ton guys
restomodbird69
06-11-2006, 06:13 PM
i dont remember how long mine took but i got lots of pics if anyone needs them.the four link took only a few hours.
VenturaII
06-11-2006, 06:28 PM
I had about the same space on one side. I used a hammer to make it fit better.
aonghus
06-12-2006, 12:56 AM
i'd love to see all of your pics for the install resto,
I pm'ed you already lol
I can arrange a place for you to FTP them
Whistler
06-12-2006, 08:11 AM
I welded all the parts that were in direct contact, then once the metal was hot, hammered the parts that had a gap until they were flush. The thick metal of the pockets bends easier once hot from the welder.
OHCbird
06-13-2006, 08:39 PM
"tack & whack" works, eh?
I drilled the holes & plug welded along the frame rail...
RaceMan
06-14-2006, 09:22 AM
I see some of the upper shock mounts angled do they say to do that?? or are people just staggering the shocks on there own??
restomodbird69
06-14-2006, 03:38 PM
the quadralink will run straight across
JamesJ
06-15-2006, 11:46 AM
http://www.lateral-g.net/forums/showthread.php4?t=4889 here is a nice write up. Not a how to but may help some with the install.
