View Full Version : Currie CurrecTrac rear arms installed
Tudorwagon
06-11-2006, 08:21 AM
Per my previous posts:
https://www.pro-touring.com/forum/showthread.php?t=19417
https://www.pro-touring.com/forum/showthread.php?t=19288
here are a few quick photos of the Currie arms installed on my Chevelle chassis.
[/SIZE]
McssGmachine
06-11-2006, 10:36 AM
I have those on my car. Before I had hotckis CA's with full poly bushings and the ride sucked! The Currie's will give you a better ride.:)
Gbodyolds
06-11-2006, 07:27 PM
Where did you get the bracket on your rear that is holding the brake like distribution block? did the Curries come in blue like that ?
Tudorwagon
06-11-2006, 08:12 PM
I made the bracket with the help of a welding shop owner I know. It started life as a reproduction bracket which we simply lengthened to accommodate the 1/2 inch thick rear cover. It would be easy to make from scratch from flat steel stock though.
The arms came in blue from Currie.
