View Full Version : Please recommend a ball joint seperator
Joe_Rocket
06-08-2006, 10:25 PM
I want to seperate the ball joints from the spindle and I have a pickle fork, but prefer not to damage the grease boot. Is there a good tool that will push against the ball join stud?
astroracer
06-09-2006, 03:05 AM
Hey Joe, I have never used a ball joint separator.
All I do is loosen the upper and lower (if applicable) nuts, run them off to clean the threads and run them back on till three or four threads are left between the bottom of the nut and the top of the spindle. Smacking the top side with a BFH will usually knock them loose easily. Spring pressure will pop the joints and this leaves the boots intact. That's how I do it and I have never had a problem. Sometimes you have to smack em pretty good. Put a floor jack under the lower and lift it a bit to support the corner just incase the joint pops with no persuasion...
Mark
Joe_Rocket
06-09-2006, 05:05 PM
Hey, yeah, sounds like a good plan.
Thanks, much!
