69CamaroRacer
06-08-2006, 03:11 PM
I am in the market for a new cam and possibly an intake change. I have called all the major cam manufactures and of the 4 I got 4 different suggestions.https://static1.pt-content.com/images/pt/2006/06/rolleyes-1.gif go figure! Anyway I thought I would run them by you and see what kind of input I get here. Also if anyone knows a true expert in the subject and has a contact number for this person I would love to make the call and talk with them before I make the swap. ok here is what I have now. 383ci stroker with Comp magnum 286 adv. 236 236 @ .50 with a .560 in and .560 ex. The cam is the retro-fit hydro roller and I have the rev-kit from AFR. The dyno showed 337hp to the wheels @ 5800 and a torque curve that was not measured below 4500 but read 335 @ about 4500. (there was a problem with the torque reading on the dyno) The comp is 10.5-1 with 195 AFR heads and an Airgap intake. The AFR's were ported and flowed 278in and 212 ex. The stall is rated at 3000 and I can foot brakes it to 3200 and it will flash to 3500. I am not worried about vaccume to much as I have no power breaks to worry about. The only vaccume accessory I have is the RS headlight doors.
When I make the swap I was thinking of switching the springs out for the new bee-hives and running a .600ish lift
Ok here is what was suggested to me...
Mark -
Lunati Suggestions
601-13 243/251 560/565 110 LSA lunatic
7530 team g intake
Comp Cams recommends
292 300 242 248 Advertised .548 .543 110 lsa 2800-6500
66 over lap pt number 12-000-8 cs 3018-3039hr 110+4 $309.00
Ultadyne
296 302 242 248 108 lsa .530 .530
531-10 kirk $310.00
Crane Cams
240 248 .558 pn. 11hr00032 $383
106 lsa
What does everyone here think???
__________________
Mark -
Lunati Suggestions
7530 team g intake
Ultadyne
531-10 kirk $310.00
Crane Cams
106 lsa
__________________
