McGuire
06-06-2006, 01:05 PM
I just rebuilt the front end of my 69 Camaro coupe. Everything is new except the drag link and steering arms. I upgraded from manual drum brakes to PDB and from manual steering to power steering. I also upgraded to solid sub frame bushings and replaced all the control arm related things, bushings, coil springs and ball joints etc. When I installed the drivers side tie rods, they went in just like the olds ones came out, 15.5" center to center. When I installed the passenger side, I had to screw the tie rod ends almost all the way into the adj. sleeve to get the toe in to what appears to be real close. The old ones came out at 15.5" and the new ones went in at 14.75". This is with all stock replacements parts. The frame seemed square when I installed the sub frame bushings and the drag link and steering arms don't appear to be bent. I'm worried there will not be enough adjustment on the passenger side, if needed, at the alignment shop. Any ideas or suggestions? Thanks in advance.
Rick
Rick
