View Full Version : Dual 4th Gen fans on 1st Gen radiators
67 455 Bird ragtop
10-22-2004, 05:39 PM
Not sure how much this has been discussed on this sit but a guy from another board turned me on to an alternative to the Mark VIII fans and their heavy draw. He's using a dual fan set up from a 4th Gen F-body with an LT1. It fits nicely, with minimal triming, on a 4-core radiator. You can run them together or use two controllers. I plan on running a Derale adjustable controller on the secondary fan. This controller is adjustable and will also run for a few minutes after car is shut off. I will run a non adjustable one on the primary fan.
Here is a link to a story on making this controller work.
http://www.thirdgen.org/newdesign/tech/cool.shtml
Here is a link to pics of a 68 with a Rodney Red with a dual fan installed.
http://community.webshots.com/album/78146952rozApb
CarlC
10-23-2004, 07:54 AM
Torker has been running the dual fan 4th-gen fan. It works well. You can just make it out in one of the pictures on his website.
http://www.geocities.com/torkerscamaro/torker.html
The MarkVIII fan is no harder to deal with than the 4th gen fan. Both need relays, but the MarkVIII just needs a heavier duty version.
socalfandabodys
10-23-2004, 08:47 AM
When I get my car back from paint I will post pics of my installation.I mounted 02 camaro ss fans on my chevelle. I needed to use two relays because it was too much output for one. It would just keep blowing the relay. I will drive the car about 1 block and it will have cooled down 20 degrees in that short time. I highly recommend them
Drewhelm
10-25-2004, 02:01 PM
Mark,
The link you posted is of a friend on mine's car here in Houston. That setup works great. I am using the same setup out of an LT1 vette on an original 4 core radiator and it fits like it was made for that particular radiator. (very minimal trimming) I run 2 relays with a single thermostatic switch. The 455 never gets over 190.
69lt4
02-23-2005, 04:28 AM
How are you guys mounting these? Besides welding tabs to the side of the radator? Haven't decided to run these or the dual Spal fans. I need to read about the Mark fan.
Kevin
gmachinz
02-23-2005, 06:09 AM
I use the Mark VIII fan with a DC Controller from DC Controls. No need for a relay with this unit-I mounted mine by using 1/8" aluminum bar stock as brackets and just bent them to the shape I needed and fastened them to my mounting ears on the shroud. Unlike using a t-stat controller or a relay, this design allows a gradual increase in fan speed based on temperature of the coolant-no on/off cycles which mean a more stable coolant temp. It's really just a new twist on the electric fan set-up. You can get both units for about 280-290 bucks or so. Not a bad deal IMO. -Jabin
