View Full Version : big stuff 3
merlinpro69
06-04-2006, 10:21 AM
I did see a post a little while back as to set up the dist for efi...but I have a couple of ??'s. I do have the msd 2345 with adjust rotor.
I did do the 50* btdc, and centered the relutor to the pick-up...thats easy.
Now it says to roll the motor to about 30*, about max torque...ok, does that now make the mark @ 80* on the damper?
Is this where the cam sync is set up? And rotor?
Hope you guys can help as iv'e been getting some bad info...
Sparky
06-04-2006, 08:35 PM
Hopefully this will help answer some questions. If this does not help clear up the issue, plese let me know and I will do my best to help you out. The Type 4 Section mentions the Distributor you are using.
http://home.comcast.net/~sparky007/Big_Stuff_3_IPU_Setup.pdf
Sparky
merlinpro69
06-09-2006, 05:58 PM
Thanks for the info...it did help! I also did buy a dvd from "FAST" and even though I have bigstuff 3, it covers alot of stuff common with both systems...when you can see how its done, what a diff! Thanks again!
