View Full Version : QA1 Coilover Conversion/LCA ???'s
NvrDun71
05-22-2006, 04:13 PM
I purchased the GMP14 QA1 coilover conversion for my 71' Nova and am wondering if I now need a coilover specific tubular LCA.
I have been told by several trusted sources that it is a good idea to upgrade to a tubular coilover LCA when I do the swap as to not have the entire weight of the car on the two lower bolts. However I was told by QA1 that it is not necessary?
Any opinions on this and or can somebody please set the story straight for me as I would prefer just to upgrade my LCA bushings and not have to drop the extra coin unnecessarily on new coilover LCA's. :help:
baz67
05-22-2006, 04:23 PM
Your friend is correct in that all of the front end weight will now be on the shock bolts. As long as you beef up your stock LCA you should be fine.
NvrDun71
05-22-2006, 06:41 PM
In what ways can I beef it up the stock LCA?
Kenova
05-22-2006, 07:46 PM
Take a look at your control arm with the spring removed. You will notice that the area where the shock is bolted on is round with a hole in the middle for the shock. Cut a piece of steel (1/16 to 1/8 should do) approximately the same size and shape. If you can, tack weld it place on the top side of the control arm. The shock bolts will also help hold it in place. This will help to evenly distribute the load over the mounting point.
Ken
NvrDun71
05-23-2006, 06:51 AM
Thanks for the tip man, that sounds easy enough. Is this what most people do in an effort to run a coilover in a stock LCA?
Any other opinions on this?
baz67
05-23-2006, 07:16 AM
Yes, for the QA1 kit that is what should be done and I would go with the .125 plate
67 455 Bird ragtop
05-23-2006, 08:52 AM
I went with a Global West setup for my 67 Bird. Basically the same as your Nova. I have both upper and lower tubular arms with QA1 coil overs. Haven't installed them yet but look like sweet pieces.
NvrDun71
05-23-2006, 05:18 PM
Anyone have any pics of a modified stock LCA to run coilovers?
Colin Frolick
05-23-2006, 10:48 PM
here's a pic of the lower arm on my Tempest. i cut the plate to fit in the spring pocket and sit on top of the shock mount, then welded it in. then i cut the hole for the shock and drilled the bolt holes.
Colin Frolick
05-23-2006, 10:52 PM
i'm wondering though... i've seen how some people reinforce at the tip of the arm, around the ball joint, and not necessarily for coil-over use. is this also recommended?
gearbanger
05-24-2006, 05:04 AM
That is a slick job Colin, yes I think that if you are going to burn corners with your car, then it would be recommended. Dennis' website shows some pretty good detail of the mod you are talking about. I think it's onrails.com
SHANE 73Z
05-24-2006, 08:23 PM
Some people will run a strap around the balljoint vertically, to help keep cracks from developing from the bore where the ball joint presses in. Ive also seen the entire bottom of the arm boxed.
Shane
Gbodyolds
05-26-2006, 03:16 PM
who is dennis ? and do you know the correct site ? the link you left dosnt work
gearbanger
05-31-2006, 04:44 AM
Sorry, he goes by dennis68 on this site,
I think the website was www.onrails.us (http://www.onrails.us)
NvrDun71
05-31-2006, 11:11 AM
Any other resources or pics of this type of mod to a stock LCA?
