View Full Version : Door glass removal
JcGc
05-21-2006, 03:26 PM
Hey all,
I'm trying to get the door glass out of my 69 Camaro. I have no idea what I need to do to get the glass out. I have already unbolted the glass from the regulator, but I have no further ideas from here. :banghead:
Some help would be much appreciated.
paul67
05-22-2006, 04:37 AM
the is a small bolt that goes through the glass on a 67 near the door handle check that
DaveO
05-22-2006, 12:10 PM
There's a few steps, but here's the bullet points:
-Rmove the up stops from the rear guide and front lower sash channel
-Loosen the stabilizers at the top of the door frame
-Loosen the upper retaining bolts on the front & rear window guides
-Remove the lower sash-channel cam attaching nuts (PS - the studs are attached at the bottom of the window so be careful pushing these out of the channel. hold the bottom of the glass when you do this).
Lift the window thru the top of the door - you may have to slide it a little forward and tilt the glass in toward the car to get the rollers to clear the sill.
JcGc
05-22-2006, 06:11 PM
Thanks for the replies,
I will do what you guys said and see what happens.
Steve Chryssos
05-22-2006, 06:27 PM
One more step. Don't throw anything out until after you have all of your replacement hardware. Been there, done that.
