novanutcase
05-20-2006, 08:27 AM
I'm looking to put an LSx engine in my project 66 Nova. I was thinking LS2 crate. First question is if I go crate engine would it be worth it to change out the stock heads and install AFR 205's with a cam or will the stock heads and cam already give me the power the AFR's would? If it makes sense to do the LS2 head/cam swap would it be better to find a new LS2 shortblock(No Heads) and just add the AFR heads/cam on to that since I won't be needing the heads or cam that come with the crate(I'm won't need most of the other stuff that the crate motor comes with since I will be replacing that also!). Since trying to find an LS2 shortblock may be hard, would you suggest I go with an LS1 shortblock and work it from there with the same head/cam configuration?:screwy:
