View Full Version : Tell me what is wrong with my set up.
LowBuckX
05-15-2006, 10:57 PM
Stock booster and 68 Corvette disc/disc Master cylinder with 1 inch bore.
Front Calipers have 2.8 bore single piston
Rear calipers have 2.38 bore single piston <--- correction 2 13/32 or 2.406
Am I having a fluid Volume issue?
TonyL
05-15-2006, 11:01 PM
what kind of lines do you have?
what are the symptoms, what's it do?
LowBuckX
05-15-2006, 11:15 PM
Lines are as follows
Front 3/16 from Master to a "T" then 3/16 to calipers.
Rear. 1/4 from Master to adjustable prop then to axle then 3/16 out to the calipers
Problem is I have bled over a gallon through the rears and have a soft pedal still. Someone metioned in another post that I may have a volume issue.
TonyL
05-16-2006, 06:46 AM
oh I see. My first thought was, older rubber lines are swelling when the pedal is depressed. I've seen that happen a few times, Switching to braded hoses and hardline help alot. Im no expert on volumes, but im sure someone else may chime in soon.
Hidro
05-16-2006, 07:05 AM
The corvettes used 4 piston calipers in 1968.Using a single piston the volume wont be the same.
-Ed
LowBuckX
05-16-2006, 09:25 AM
-Ed
Can you elaborate? Too much .. not enough..
Hidro
05-16-2006, 09:38 AM
4 piston calipers use less volume and less pressure than a single piston caliper. (from wilwood website)
-Ed
LowBuckX
05-16-2006, 11:48 AM
Then what Master should I be running?
LowBuckX
05-16-2006, 04:27 PM
:help:
6'9"Witha69
05-16-2006, 05:21 PM
A larger MC may help. I just re read this and the other thread and noticed something. You never indicated if you removed th hold off valve in the rear lines. You didn't mention it in the order, just wondering if it is still there. second thing may be residual pressure valves. I HAD to run one in my rear line to keep the pedal up. It would bleed off FAST without it. If it sat for more than a day I had almost no pedal. An indicator is if you can pump a couple times and get a good pedal, then as you hold it firm, it goes soft under your foot. It can feel like a bad MC sometimes.
LowBuckX
05-16-2006, 08:31 PM
No hold off.
I was hoping for a confirmation on the residual checks. I will add one this weekend.
If that doesnt give me a pedal I will add a larger master I guess.
OHCbird
05-16-2006, 08:48 PM
What calipers are you running?
You shouldn't need RPVs in a properly bled system; any residual pressure on the rear caliper will drag the pads. Do you have an adjustable prop valve plumbed in?
sinned
05-16-2006, 09:14 PM
Let’s start from the beginning as there is a lot of misinformation going around here. You state you have a "soft" pedal, what exactly does that mean? Is that engine off or engine on, are you running a booster or manual system? How is the pedal height? If this condition exists while driving, does it improve with a few strokes and what pad compound are you running? Do you have a residual valve at all (yes, even disc systems need residual valves albeit rated quite a bit lower than the drum versions)?
Brake line size will have no affect or pedal sponginess. It can cause a touchy pedal and affect pedal height to some degree but never a “soft” pedal. As Tony alluded to already, how are the flexible brake hoses?
LowBuckX
05-16-2006, 10:35 PM
All flexi lines are new.
I have an adjustable prop plimbed in.
No metering block and no check valve.
Soft pedal is with engine off. With engine on I can get a pedal but with a few pumps.
front calipers are stock 72 nova units
rear are GM Metric "fronts" from an 85 Camaro (front)
just now I got back from the garage. I took calipers off the brackets suspended them in the air with bleeder on top. gravity then vacum bled them while taping and shaking them.(speed bleeders removed and standard in place. . 0 air from either side.
Please explain "PEDAL HEIGHT"
Sleight pressure starts from about 1/4 of total stroke. Or 1.5 inch from top
sinned
05-17-2006, 04:32 AM
Pedal height is how far from the top the pedal sits when fully depressed. I’m still confused about "soft" pedal. Is it spongy feeling, or does sink once it initially grabs? What type of booster if any and you state the pedal gets better after a few pumps with the engine running, does it not get better with the engine off?
LowBuckX
05-17-2006, 08:31 PM
Pedal height is 1.5 inch from the bottom. after 2 pumps it is at 2.5. Wait about 10 seconds then push iit will go back to 1.5.
This is also from pedal to carpet not to the metal.
Soft pedal meaning. My pedal used to be a rock with the engine off. Now with the discs and the Vette master it has nothing.
sinned
05-17-2006, 08:43 PM
I am thinking an air problem, you state you have bleed the brakes quite a bit, fronts too? What bleeding method are you using?
LowBuckX
05-17-2006, 08:59 PM
Ive pumped them out with just the speed bleeders and a container. Ive used a Mightyvac.
I dont have any help to do a 2 man bleed. I dont see any air when useing the mightyvac on the fronts either.
I am building a pressure bleeder that looks like the motive bleeder. Would that help?
LowBuckX
05-21-2006, 02:12 AM
Well I did a butt load of research and the best answer was given in 2004 by David pozzi on a camaro board.
A 2 lb residual pressure valve wouldn't hurt at all, might help a little.
A couple of problems arise using the S-10 calipers.
1. they have a much larger bore than is needed for a rear caliper, this uses up fluid volume pumped by the master cyl and you have excess pedal travel problems. You also have to use an adjustable proportioning valve to lower the rear pressure.
2. Those calipers are "Low Drag" type with a different seal angle that retracts the pistons more than usual. It is used with a special "Quick Take Up" (QTU) master cyl with a third, much larger piston at the rear of it that displaces more fluid volume until 100 psi line pressure is reached, then the third piston pressure above 100 psi is returned to the reservoir and the smaller MC pistons will develop the pressure. think of it as a two stage master cyl, the first portion of travel delivers high volume at low pressure, moves the caliper pistons out to touch the rotors, then the two pressure pistons take over.
Your choices are to either use smaller rear caliper bores, or think about the QTU master cyl. This master cyl has a much larger rear portion where it pilots into the brake booster so you would have to find an 80's Camaro booster to use along with it. It won't fit your firstgen booster.
I would rather see you find a smaller bore caliper. It would be great if there was one with the same mounts and rotor thickness as what you have now, but I don't know of any.
Maybe you can find something. Otherwise I remember my 89-91 IROC had aluminum rear calipers and used the S-10 type front calipers, so the F/R ratios should be correct for your application. Rear discs were an option, also pre-89 Camaros and Firebirds had cast iron rear calipers that some of them had self adjuster problems but those calipers are probably more common. The Cadillac Seville had the same iron calipers. The rotors are probably around .8" thick, but I'm guessing. The axle flange OD may need to be turned down to fit the rotor.
Before you give up on what you have, make sure your brakes have been well bled and the calipers are not twisting when you apply the brakes sitting still. If they are twisting that is using up pedal travel too. Make sure all bleed screws are pointing up so all the air is bled out.
David
But all is not lost Ive also found what maybe the solution. 1977 monza booster with a 1986 disc disc master.
If it dont work Im done for the year and I will be ebay ing off my my newly aquirred shiney junk.
andrewb70
05-21-2006, 07:55 AM
The pistons in your rear calipers are HUGE! Especially when you compare them to the fronts. My theory is that your rear brakes are barely working. Your soft pedal is a result of not enough fluid being pumped to the rear calipers with a single stroke. This is confirmed by the fact that pumping the pedal helps. If you get a bigger MC sush as a 1 1/8" bore that will solve your soft pedal issue, however it will create a host another problem. Since your rear caliper bore is so large your rear brakes will now be prone to premature lock up. Your piston areas are so out of whack that a prop valve may not even be able to have the required range of adjustment to tune out the premature braking.
This is also common with guys running the Explorer rear brakes on Ford 9" rear ends. Thats just my take on the whole thing....
LowBuckX
05-21-2006, 08:12 AM
The rear Cadillac Seville swap are also 2.406 just with an e brake? Why does that work but not mine? Also the WS6 calipers are the same
andrewb70
05-21-2006, 08:30 AM
Good questions. I am not sure that I can give you an answer from my living room. One theory is that those cars used a bigger bore MC. As far as the balance issue, many things such as front rear weight distribution, suspension geometry, springs, shocks, etc...will all play a part in how balanced the systen will be.
What year Seville and WS6?
sinned
05-21-2006, 08:38 AM
1 1/4" master and an adjustable rear balance valve (also known as an adjustable proportioning valve). Andrew is correct about the size of those calipers, they are fairly big. I’ll bet both the Seville and WS6 run at least 1 1/8" bores which is why they work.
Yes, a pressure bleeder will work much better than a Mity-vac.
LowBuckX
05-21-2006, 10:12 AM
85 caddy Seville Master acording to www.napaautoparts.com (http://www.napaautoparts.com) The !985 Cadillac Seville Master is a 1 inch bore.... But the pic looks to be of a QTU type master. http://www.napaautoparts.com/masterpages/NOLMaster.aspx?PageId=470&LineCode=TS&PartNumber=101904&Description=Brake+Master+Cylinder+-+Remfd
andrewb70
05-21-2006, 03:59 PM
I found the 85 Seville MC listed on the RockAuto website. The AC Delco PN is 18M186. The discription reads: 25.4 and 36.0mm cylinder bore. That means it is a quicktake up style MC that is similar to the one I am using on my GTO. I bet anything that the 36mm bore port is for the rear and the 25.4mm port is for the front. Makes perfect sense given the large piston area of the rear calipers. On my GTO I have the rear port plumbed to the front since my 6 piston calipers need more volume.
LowBuckX
05-21-2006, 09:28 PM
Now all I need to do is find a way to see how the factory has the 85 seville routed. This guy has an 86 Camaro Master running his swap that is the same as mine. I see he has the front portion of the Master running to the rear.
He claimes he has a firm high pedal like Im looking for.
You can see his Adjustable prop valve plumbed to the front section of the master. https://static1.pt-content.com/images/noimg.gif
He has the snout of his master turned down to 1.48 to fit in his booster.
Is it possible to cut down the push rod on the booster seeing I have the deep style and the QTU takes a shallow style?
But the Camaro Master according to Rock auto is 24MM and 31.75mm so the seville may be a better choice
andrewb70
05-22-2006, 04:58 AM
At this point I think you will just have to experiment. I think getting a larger bore MC is definitely going to help. The guy with the 86 Camaro MC no doubt has a very nice firm pedal considering he plumbed the 31.75mm (1.25") piston to the front brakes. The question is how effective are his rear brakes with the 24mm MC bore being plumbed to them. His rear brakes may not be doing much of anything. With the large bore port plumbed to the front he is getting the illusion of great brakes. Firm pedal, fast responce, etc....Just thinking out loud..
05-22-2006, 08:30 AM
Get a stock 1 1/8" cast iron master cyl for your car, that is what it should have used originally. Your front calipers need the 1 1/8" bore MC.
Your rear calipers may work OK with this combo. some of the Ford rear calipers are over 3" bore and those really cause a low pedal. Avoid the Quick Take Up MC if you can, it's hard to find a good one that works well and they are a pain to bleed.
LowBuckX
05-22-2006, 08:22 PM
Should I just get a 1 1/8 Disc disc master Ala 68 vette with power brakes. Still fairly inexspensive.
I am PMing you David on an Idea Ive come up with.
LowBuckX
05-22-2006, 10:37 PM
Well I have been given some missinformation. The seville rears even though they share the same mounting and basic shape of the fronts Only have a 2.121 piston. But the 79 pontiac TA rear caliper has a 2.49 piston.
EastCoast
05-23-2006, 06:20 AM
I'm just in the process of finishing this same basic setup. Single piston caliper on the front with 13 inch rotors. Single piston 'metric' calipers on the rear from an 81 Malibu with a 12 inch rotor. I'm using an 1 1/8 MC from a 72 vette with a 2lb residual valve in the rear line and an adjustable prop valve. Still fine tuning, but it seems to working out.
There's some details of my trials & tribulations over here....
http://www.camaros.net/forums/showthread.php?t=77947
Hope it helps
Robb
andrewb70
05-24-2006, 11:53 AM
Misinformation? On the Internet? How is this possible?
:rotfl:
2.121" is still pretty big, but definitely better than 2.49". Try the 1 1/8" MC and I think you will be good to go.
BRIAN
05-24-2006, 06:50 PM
Why don't you start from the basics before you go swapping out parts. Residual valve on the rear correct? Have you tried full out and full in?
Actually I would first take a vacum reading at the booster to verify correct vacum to operate booster. Than I would take off the front and rear lines and plug the master cylinder to verify it is working properly? You did bench blead the master correct? The rod for the master is on the right hole on the brake pedal? Those rear calipers are notorious for bleeding problems. Invest in a Motive pressure bleeder. Makes easy one man bleeds and is relativly cheap. Try tapping on them it usually frees up some air. The Mityvac is probably your biggest problem but that is another story.
If all from there is ok than start with the swapping of parts. Call Mater Power brakes or look on their web site. They are great source of free info
I am running Metric GM calipers in the front, Seville rear calipers and a 1" master. I have perfect vacum but could only fit a 7" master. With some playing it has firm but great stopping power with simple Hawk pads. The pads were probably the best investment on that system. Not one special part needed.
Good luck.
LowBuckX
05-24-2006, 09:15 PM
Hi brian I will aswer your questions in order.
Not sure 2# for discs where recommended
On the adjustable valve.. if so yes
Booster is proven to work
yes I did a second time to make sure
Built my own out of an ace garden sprayer and odds and ends I had around the shop. Works awsome that is why Im sure I have 0 air in lines.
I got a 1 1/8 disc disc master today. $16 plus $5 core via advance auto.
Will try it in a few minutes..
LowBuckX
05-24-2006, 09:50 PM
Ok my pedal is up like I like it but I cant say forsure if it is right yet till I bleed it again
BonzoHansen
05-25-2006, 08:54 AM
Built my own out of an ace garden sprayer and odds and ends I had around the shop. Works awesome that is why I’m sure I have 0 air in lines. Someday, when you have time, you need to show that little contraption!
LowBuckX
05-25-2006, 10:41 PM
Well good News I have great pedal now after the 1 1/8 master.
I originally started with a 1 1/8 disc/drum Master and it didnt work thats when I went to the 1" disc disc as recommended by someone who got his to work.
Now Im gonna screw it all up again and do a pdqCBB front set up or some thing close.
BonzoHansen I started a new post with a pic of the so call contraption.
BRIAN
05-26-2006, 06:10 PM
The problem with those Vette style masters is there are about 20 different versions out there. Than throw in the offshore stuff marketed as disc or drum and you can see where there can be problems. I went through 3 before I invested in a stainless sleeved deal and has been perfect since. Try some better pads you will be impressed, at least I was. Bought Hawk pads I think at Pep Boys and will never go back to stock.
Glad it worked out for you.
