View Full Version : Adding a return line for my 69 Camaro
brianjw4
05-09-2006, 09:14 AM
How hard is it to add a return line to my stock 69 camaro tank?
I have seen some threads about installing an in-tank unit, but I think I will just stick to an external pump.
big block tank sender with return line
https://static1.pt-content.com/images/pt/2007/08/a8_1_bJPG-1.jpg
CarlC
08-16-2007, 02:07 PM
You can also drill and braze/solder a new return fitting into your existing sending unit.
dsw12387
08-16-2007, 08:25 PM
So does a big block sender come factory with a return line
TnBlkC230WZ
08-16-2007, 08:42 PM
The second line on those are vent returns. They are only 1/4 inch. Return line should be the same size as the fuel line.
Fuelie Fan
08-16-2007, 10:25 PM
Not true. "Most" factory systems are 3/8" feed, 5/16" return. A neck down to 1/4", if only for a very short length (ie don't plumb the whole return with 1/4", just step down at the tank), would not be a huge deal. As flow rates increase it becomes more of an issue. This would be totally fine with a 255 l/hr, but probably undesireable with an A1000 for example.
does the tank have to be sumped to use an external walbro 255 with that pickup?
CarlC
08-17-2007, 04:52 PM
It probably does not have to be, but at less than 1/4 tank you may run into regular fuel starvation problems. It will get worse on a road/AX course.
