View Full Version : PN for tko 600...
kman67rsss
10-17-2004, 06:38 PM
i am looking for a PN for a plug that i can use for by reverse light switch on a TKO 600. thanks
kman67rsss
10-19-2004, 11:50 AM
wow, all these views and nobdy, o well i will take a trip to the store and see what they have
Hurst - Jeff
10-19-2004, 04:58 PM
I have searched high and low for a pre-made plug for the reverse light switch and I have not found one.
I tried Ford, auto electric specialists, terminal supply company's and have had no luck.
I used a plug taken from the wiring harness of a junked 1990 Mustang (with manual transmission) and it snapped right into place. You can read my install write up to see how I handled this connection: http://www.classicchevy5speed.com/tremec_transmission_1970_camaro_wu.htm.
I hope this helps. Sorry I did not respond sooner.
kman67rsss
10-19-2004, 05:25 PM
ok, i had seen that but thought there was a PN for that plug. you wouldnt happen to know what that plug was for on the mustang would you?
Hurst - Jeff
10-19-2004, 06:07 PM
The plug on the Mustang was used for the same switch - the reverse light switch on the Mustang's transmssion.
I cheked with Ford and showed to Ford part's guy's the plug and they both said that i would need to buy th eenitire wiring harness to get that plug - it is not sold as a sepearte item. If you find out differently let me know.
kman67rsss
10-19-2004, 06:15 PM
ok, thanks. i will try anyways, if not i will take a trip to a local junk yard
