View Full Version : LS1 Rear brake problems
tyson__91
05-08-2006, 10:09 PM
When putting my rear brake setup on my 68 Camaro's factory 10-bolt. I ran into a problem with the rotor hitting the out side of the caliper basket (seen in the picture attached). It could be fixed by spacing the backing plate out from the axle flange but is this something people usually run into while doing this swap. By the way you guys talk everything just slides on. Thanks for your help.
noels69
05-09-2006, 10:07 AM
I did this swap and did have to pull the axles and make approximately a 3/16" spacer for the backing plate. This spaced the basket out enough to get the right clearances for the rotor.
Noel
Midnight68
05-09-2006, 09:06 PM
What did you make the spacer out of? I am having this same problem.
EFI69Cam
05-10-2006, 07:41 AM
I made mine out of a moser c clip eliminator axle retainer
