View Full Version : Wheel Fitment for A body Olds.
WhiteNoma
05-06-2006, 11:10 PM
i'm looking into to 17" torque thrusts for my 68 Olds Cutlass. i wanting to fit the largest tire and rim possible out back without mini-tubbing. would it be possible to get a 315/40/17 on a 10" rim to fit easily?
any offset suggestions?
Thanks.
andrewb70
05-07-2006, 06:36 AM
I am not aware of that size tire. Maybe you mean a 315/35-17?
NvrDun71
05-08-2006, 12:59 PM
Man just mini tub that beast already and throw some 345's on.......J/P. Heres a bump for ya hopefully, somebody on here will chime in..........
andrewb70
05-08-2006, 04:33 PM
A-bodies are not constructed like Nova's or Camaros. You can't just mini-tub it. Way more to it than that.
NvrDun71
05-08-2006, 05:32 PM
Didn't realize that man but makes since they are not a unibody car....... Thanks for the lesson. In your experience with A-body's what is the biggest wheel tire combo w/out wheelwell modification and stock width rear?
shep
05-08-2006, 06:16 PM
http://carcraft.com/techarticles/3636/index.html here is a place to start the article says 315/35 on an 11 inch wheel
PT Goat
05-09-2006, 09:14 AM
Here's the link you need: http://www.oldsmobility.com/fitting-wheels.htm
andrewb70
05-09-2006, 09:23 AM
With careful wheel selection and assuming that the body sits evenly on the frame (many times it does not) you can fit the 315/35/17. I run 295/45/18s on my GTO on a 10.5 wide wheel with 6 inches of backspacing.
NvrDun71
05-19-2006, 05:55 AM
Hey Fritzsch...ck out the rim/tire specs and backspacing on the chevelle in this link:
https://www.pro-touring.com/forum/showthread.php?t=18786
WhiteNoma
05-31-2006, 03:22 PM
ok guys, thanks again for the help... the wheel size im looking at is a 305/45/18 Nitto drag radial, on a 9.5" rim... im assuming the dimensions will still work due to being narrower than the 315/17's. i dont believe i will have any height problems. If anyone knows different please let me know.
philbay
06-02-2006, 02:18 AM
minimum needed with 10s are 4.5... I should know I bought these froim an olds,thinking....A body=olds=chevelle==same same.. answere NO>>>> so you need 4.5 .
WhiteNoma
06-02-2006, 06:08 AM
so the offset on the 18"X9.5"s im going to buy needs to be 4.5"... ?
thanks for the info.
