View Full Version : 1/2 dropped body mounts
Jinks
05-03-2006, 10:36 PM
is there any reason NOT to run these body mounts other than a more limited tire clearance in the wheel wells?
vanzuuk1
05-04-2006, 03:09 AM
You end up with less clearance between the trans and trans tunnel and your hood is closer to your air cleaner. You may need to realign your steering column a little, loosen and retighten.
None of this was a big deal for me,you should be fine.
Jinks
05-04-2006, 06:10 AM
ok thanks for hte heads up
