View Full Version : Should I race an 06 Z06?
DReid
05-02-2006, 06:52 PM
I have 600 miles on a fresh 383 Stroker in my 67 Camaro Coupe. The guy down the street in his Stock 06 Z06 wants to line them up.
I have never raced the car and do not want the first time to be a bad experience. With what I list below... SHOULD I be worried? Assuming I hook up and no missed gears etc etc....
Engine
383 Stroker
Edelbrock Air Gap (Permastar finish)/port & polish match with heads
Barry Grant Speed Demon 750 electric choke VS
Vintage Air Frontrunner Serpentine belt drive system
Edlebrock Performer Aluminum heads 2.02 Full street port/polish
Keith Black 10.3 – Pistions
Comp Cam 280H Duration at .050 – 231
Hardened comp cams push rods
All ARP bolts
Flowtech hot jet coated 1 5/8 inch full length headers
3 inch mandrell bent with Flowmaster 40 series
Tremec TKO 500
Centerforce Dual friction clutch/pressure plate
Centerforce bell housing
8.5 inch ten bolt posi built by Pyle Brothers
Eaton posi 3.55 gear
Superior Axels
Global West tubular upper & lower control arms with del a lum bushings
QA1 single adjust coil over shocks
Hotchkiss rear lowering (1 ½ inch) leaf springs
Poly urethane bushings all around including motor and transmission mounts
2 inch Superior drop spindles
Steering
Detroit Speed & Engineering quick ratio power steering gearbox
Tilt ColumnCooling
Be cool polished aluminum radiator
Spall 14 inch electric fan
Stewart high flow T-Stat AC/Heat
Vintage air Gen II heat and cool
Brakes
Baer Brakes – Front Track system 13 inch slotted/cross drilled, zinc washed rotor, 4 piston calipers. Rear – Touring system 12 inch slotted/cross drilled, zinc washed rotor, 1 piston calipers
Stainless and or braided stainless lines throughout
Wheels
Budnik Hammer Brushed center, polished hoop, soft lip
Front – 18 X 8 with 4.75 back spacing
Rear – 18 X 9 with 5.375 back spacing
Tires
Nitto 555 Extreme
Front – 235/40/18
Rear – 275/40/18
Electronics
Painless wiring complete 18 block wiring harness
Auto meter gauges
Ignition
MSD 6 Ignition
MSD Pro billet distributor
MSD 8.5 mm plug wires
05-02-2006, 07:25 PM
you might want to go get a couple under your belt before you tackle that one. If its for fun at the track go for it.
4MuscleMachines
05-02-2006, 09:20 PM
At the track is where it belongs, but be prepared to get :spank2:
rocketman
05-02-2006, 09:29 PM
have to say he'd walk off from you,you have a nice package but its not 500 hp.a new z06 will run 11's
sinned
05-02-2006, 09:39 PM
I'm sure you would have fun but your going to get spanked. Your combo MIGHT pull a high 12 with perfect conditions and a good driver.
camcojb
05-02-2006, 09:45 PM
A friend took his 18 mile 06 Z06 straight to the dragstrip and ran an 11.3X. I do not think you can hang with that.
Jody
zbugger
05-02-2006, 10:06 PM
Should you be worried? No. You should be expecting to be spanked. But I say go for it. It would be fun, and a good learning experience. heh.. Learning what the back end of an '06 Z06 looks like....
Damn True
05-02-2006, 10:15 PM
Have you ever heard one of those things at full throttle? It would be worth losing (and you will) just to hear that.
Do it on the track or you are a moron.
69rs
05-03-2006, 02:40 AM
Besides, if he screws up and you win, you've beat a Z-06! :1st:
vanzuuk1
05-03-2006, 03:08 AM
I am generally against street racing, but the other day I passed a z06 like it was standing still. I was in my buddys Noble gt, the noble goes from 60 to 140 in a heartbeat. The guy in the vette wanted to go again but I did the mature thing for once and waved him off. I have a photo of the noble but i cant resize it.
Threadjack over,sorry.
ProdigyCustoms
05-03-2006, 03:46 AM
You gonna get your ass kicked! You will need some giggle gas to handle that thing
Jagarang
05-03-2006, 04:25 AM
It's not just about 500 HP. It lighter, has traction control, has a lower drag coefficient, wider tires, computer tuning, etc
Who cares anyway, it's all for fun, and it'll let you know where you stand in the muscle car hierarchy!
Steve68
Yea, The naaaus, put a 200 shot on it, then race him!!!
Varkwso
05-03-2006, 04:49 AM
I assume you are talking Drag racing :2nd: - you do not have a chance on any road course. You are going to get spanked unless he really screws the pooch on launch.....but it is all in fun right? I can chase down most cars in my 2002 ZO6 even if I cannot buy a decent 60 foot time - and I would get stomped by a 06 ZO6 with a driver that is not asleep...
CAMAROBOY69
05-03-2006, 04:56 AM
Rear – 275/40/18
Thats the first problem right there. 500hp and trying to launch on those tires. Your wont go anywhere. Believe me I know. I only have 400hp with those tires and from a dead stop I dont have traction. If you are doing 1/4 mile against this guy and you have no experience, you will get stomped. Now if you were both on a road track you have a little better chance of keeping up but you will still loose. Those 06 ZO6 are bad ass machines and you would need one heck of a car to keep up on a drag strip or even on a road course. But if its just for fun then go for it and get video.
Do it on the track not on the street.
CAMAROBOY69
05-03-2006, 05:03 AM
Here is a pic of his car. Looks nice.
TOPDOWN CRUISER
05-03-2006, 05:44 AM
Sounds like fun, id try him out.:3gears:
Damn True
05-03-2006, 07:19 AM
Nice car!
But you'll still get your :moon: handed to ya.
Taylor1969
05-03-2006, 07:39 AM
A Z06 with an average driver would absolutely tear your car up. Your car is awesome, but the Z06 is a factory supercar and has a lot of technology in it, weight and weight distribution are a huge factor, much less the 500 horsepower it has.
Taylor1969
05-03-2006, 07:40 AM
BTW... i love the Hammer's... I am debating between those wheels and the standard TT2's. Not sure yet if I want to pony up the extra dough that the Budniks command.
DJW32
05-03-2006, 08:00 AM
You will definitely need a power added...and slicks
Stuart Adams
05-03-2006, 08:03 AM
Either vette versions for 06 will pull away from you, but I would give it a try and have fun. Go for a ride in the Z06 when done.
rob07002
05-03-2006, 09:38 AM
Spray it 60' out and wave bye bye!
Kustom_dude
05-03-2006, 02:55 PM
All I have to say is go pick up this months Motor Trend and look at Target Z06.
4MuscleMachines
05-03-2006, 11:09 PM
I've seen upper 10's with etMT's, long tubes, tune, and no filter.:drive2:
DReid
05-04-2006, 04:37 AM
WOW! Funny stuff but I'm sure it's accurate. I had a couple of C-5's that seemed like dogs compared to the Camaro but both were auto's and pretty much had highway gearing. The TKO and lot's of tourque have most likely given me a false sense of security/ego.
Anyway thanks for the comments on the ride - almost done and I'll update that site b/c I've changed some things inside.
DReid
05-04-2006, 04:52 AM
Thanks - it's not that much more is it???? IMO wheels make or break most cars and their chance of standing out. If not Budniks then some off brand no one sees or has. The look a lot like the Fikse F5 - now the Budniks seem cheap. See it's all a matter of perspective. :hammer:
MarkM66
05-04-2006, 05:27 AM
Try to negotiate like on "Pinks", try to get about 20 cars, lol.
OldSchoolFormula
05-17-2006, 09:11 PM
Race him with depreciation. Add 1 years depreciation of the Z06 to your ride in the form of a hairdryer and all kinds of other goodies. Race again. Problem solved.
Its just too bad that C6 Z06 is sooooooo freaking ugly. Hand me a C5 Z06 and let me spend a couple bucks on mods (or an LS7 transplant) and I'd be a much happier person.
Back to the real world though, and your toast.
CAMAROBOY69
05-18-2006, 04:03 AM
I personally think the 06 Z06 is the best looking Corvette so far. Just my opinion.
6'9"Witha69
05-18-2006, 08:21 AM
I like the C6 best so far as well. You will get it handed to you though. Not enough cam and too much exhaust. Combine that w/ poor traction and he will be at half track by the time you stop spinning the wheels. I can walk all over C5 Z06s, but have not had it out recently enough to compare to the C6.
ZZ430
05-18-2006, 08:39 AM
The C6 ZO6 is the first Corvette I would even consider since about 1967.
I love the performance....Wow
OldSchoolFormula
05-18-2006, 02:17 PM
You guys are crazy. :hammer: The C5 is such a sexy lady... and the C6 is like the same sexy lady, but on steroids, and injected with enough testosterone for a dozen men, as a huge body builder.
Yep. Crazy. Whatever floats your guys boats. LOL. No denying her performance though, especially in sheer... power. :hammer:
Varkwso
05-18-2006, 02:25 PM
Pretty is as pretty does and the new ZO6 is a incredible machine. I like it a lot.
John McIntire
05-18-2006, 02:40 PM
I agree, The new c6 ZO6 is absolutely an amazing car for the money. I'd gladly trade my Chevelle for one.
Dan Sherwood
05-19-2006, 10:26 PM
I guess there are not any "fast" 06 Z06's at the drag track I frequent. I have yet to see one get into the 11's. I'm sure they would smoke my 69 camaro at the road course, but I'd run one at the dragstrip anytime (550+hp 406). High mph, but traction challenged, even with whatever drag tires they can get to fit.
I like the vette, but probably would not trade my overweight camaro for one. Especially after putting the smack down on 2 on drag night, and I'm setup to run right at the 11.5 mark so I don't get booted out. 11.5 @ 118+ still gets there sooner than 12.1 @ 120+.
Out of 5 different 06 standard vettes, I've only seen 2 get into the 12's. Again, traction issues, but the mph tells me they should run mid 12's.
I'd get some stickier tires if possible, and give him a qtr mile run. You MIGHT be suprised. I think it would be closer than most folks think.
bingham72
05-23-2006, 06:37 AM
do it, race 'em, (on the track of course), film it, post it. LOVE IT!!!
who care's who wins unless you are racing for pink slips!
It's all good!:cheers:
Doug G
06-04-2006, 05:50 AM
With that combo Vs. the Vette he's got it... if he can hook and is even a little bit of a good driver.
I have that cam in my 406 below.DA was 1800', and 82*.
Varkwso
06-07-2006, 03:32 PM
I saw an 06 ZO6 turn 12.1 at ~120 at South GA Motorsports drag strip on the Hot Rod Power Tour on Monday. He smoked a Ford GT by the way.....:cool:
It was HOT and traction seemed to be an issue.
Dan Sherwood
06-07-2006, 10:00 PM
Borrow some slicks or at least some et streets, set to 13 lbs, do a nice looong burnout, be the first off the line, and pray he gets no traction, and you could very well beat him to the stripe.
I say a resounding-heck yes, race the dude!!!!!!!!!!!!!
John McIntire
06-08-2006, 01:44 PM
Latest GM Hightech Performance took a stock 06 Z06 and slapped some drag radials on it and went 11.73...................
camcojb
06-08-2006, 09:23 PM
I've seen a friend go 11.30's as I said. He's a very good driver.
I just ordered an 07 Z06 myself!:cool:
Jody
Blown353
06-08-2006, 10:56 PM
Jody
Mmmm, LS7. What are you going to do with the Goat?
Varkwso
06-09-2006, 03:30 AM
Jody
Boy am I jealous :jump: - so I guess we will see you on a road course when the car hits a 1000 miles or so?:3gears:
camcojb
06-09-2006, 06:03 AM
selling the mods and will sell the car when the Z06 is closer to arriving. Right now I'm looking at 6 months unless something turns up sooner.
Jody
camcojb
06-09-2006, 06:04 AM
Yes I will. Charley likes to do the open track days and although a new Z06 makes it easier to drive on a track it will still be a blast. He wants me to use an older car so I "learn more"!
Jody
