View Full Version : Ron Davis Radiators
HOT OHC
10-14-2004, 07:51 PM
I know this is not the correct fourm to post this but want to know if anyone has used http://www.rondavisradiators.com/radgallery.htm Just wanted some feedback of the quality/support. I am interested in either of the 67'-69' Camaro/Firebird models.
https://static1.pt-content.com/images/pt/2004/10/1116CA69002-1.jpg
Steve1968LS2
10-14-2004, 07:59 PM
Ive always heard good things about Ron Davis.. Another option is Alumrad in Arizona he did my custom "two on the right" radiator... nice guy..
http://www.alumrad.com/
At least this way you can price shop :)
nancejd
10-14-2004, 08:05 PM
I haven't installed mine yet, so I can't speak to quality of function, but from a construction viewpoint it is truly a work of art.
HOT OHC
10-14-2004, 08:09 PM
Steve1969LS1- Thanks for the link, yes always nice to price shop. Funny both companys are in Arizona, makes sense to me.
nancejd- How much did you pay and which model did you get?
67rsconvert
10-14-2004, 08:11 PM
I'll have my ron davis installed in another 1-2 weeks. as was said construction is beautiful. Very nice stuff. I'll update after it is tested.
Ralph LoGrasso
10-14-2004, 08:27 PM
My Ron Davis is beautiful. Truly TOP notch stuff. Highly recommended.
I have that exact setup, that picture does no justice, top notch quality!! Also if you get the universal setup it is real cheap! I highly recommend them and that exact radiator setup, no headaches in mounting the fan, also they have a higher fin count than most of the other rad companies. Also the welds are a work of art. check mine out, my upper rad bracket isn't done yet;
okay, nut juggling is over
ALLFAITH
10-15-2004, 03:29 AM
I have a Ron Davis radiator in my 65 Mustang with 500HP. It never, and I mean never runs hot, it will not go over 190 even idling in the heat. In addition, it looks perfect and have had no problems for the 6 plus years it has been in the car.
Brad
HOT OHC
10-15-2004, 10:13 AM
Well thanks for all your input guys but it seems now that their electric fan version is just too thick to fit my application:pat: So I may get their standard one and stick with my HP robbing, finger cutting mechanical fan:crying:
PTAddict
10-15-2004, 07:31 PM
I have a Ron Davis 31 inch cross flow radiator on my '67 540 CI aluminum big block, with dual electric fans and shroud. It has a 180 degree fan switch, and the coolant temp never goes over 180. Amazing.
Highly recommended.
BTW, my radiator is the exact same configuration as Larry Callahan's.
actually i used the rad/fan setup because it was the thinnest thing out there, At first i had a mark VIII but there was no way i could fit it. I am running a BBC with long water pump, i don't think i could even fit a mechanical fan if i wanted.
HOT OHC
10-16-2004, 10:10 AM
Yody- I only have about 6" of space to fit the rad & fans. The one pictured in my first post is over 8". It has a built in shroud that adds to it's depth. Yours does look awsome.
So this version my be the way to go for me.
https://static1.pt-content.com/images/pt/2004/10/cupbrackets-1.jpg
Larry Callahan
10-16-2004, 11:01 AM
PTAddict, glad to hear yours is cooling well being it's the same as mine. I only put about 20 miles on mine before I tore the car apart. I can tell you I love my radiator. I think it's a killer radiator and I can't wait to put it to the test. To top off how well it's built it's just a KILLER looking radiator. They also built my intercooler and it's just as cool.
LIL NOVE
10-23-2004, 03:06 PM
here's a pic of mine. sorry the shot wasnt closer. it works great w/ my CSI electric water pump, the needle on the gauge literally jumps down.
JOHN
1966 CHEVY II
OHCbird
10-23-2004, 11:04 PM
Eric-
I'm using a 27" universal with a Spal dual 11" setup. No pics yet, but the dual fans are offset, giving us the room we need in the middle. I only had 5.5" with my 3-core & dual belt balancer.
How's progress coming?
Pzary3233
10-24-2004, 08:02 AM
Here is another option to think about
http://www.rodneyred.com/
He's a pontiac guy and build custom radiators. A lot of the guys on other pontiac forums like his products.
HOT OHC
10-24-2004, 09:31 AM
Eric-
How's progress coming?I ended up going with http://www.alumrad.com/ (http://www.alumrad.com/) Like Ron Davis, Alumrad makes a direct replacement but he is making the mounting brackets shallower than stock giving me a little more room. The radiator support lip will neen to be shaved in a few spots. I am not sure if this is normal but on my car the hole in the radiator support is off center towards the driverside. So I am going to use a 16" Spal single fan and off set it a little more to clear the water pump.
Alumrad also mounts the temperature sensor in the return side of the radiator. They say by doing this you make the thermostat and fan temp sensor work together. Thermostat keeping the motor at a constant temperature and the fan keeping the return coolant at a cooler temperature.
