View Full Version : how's this combo
ponchopwr70
04-24-2006, 12:36 PM
Hey everyone. I just blew my 355 i built 3 years ago. was a .030 350 with 10.1 forged pistons lunati rods, comp hyd cam 487/490 lift 2.02 bowtie heads ported+polished, 1.5 roller rockers, 70 z/28 intake, holley 750 vac secondaries, stock hei, stock timing chain, stock auto zone fuel pump and stock oil pan. Since my crank is scored and a couple cam lobes ground down to nothing I'm gonna rebuild it. How's this sound, turing it into a 383 (388 with the 3.040 bore) Going to be broke now since i just ordered my rims before this happen.
Stuff i'm keeping
-Heads
-Rockers
-Intake
-carb
-distributor
Stuff i'm buying
- lunati sledge hammer crank 3.75 stroke
-bore block to .040 over
-srp pistons for 3.75 crank with 5.7 rod flat tops 3.040 bore
-lunati voodoo cam 268 489/504 lift with mathing springs
-cloyes true double roller with milodon reinforced cover and button
-milodon 5qt pan with baffle and windage tray
-mel high volume hv55 pump
-carter street pump 6 psi
-hypertech cap,rotor and 50,000 volt coil
-fedral mougal bearings
rocketman
04-24-2006, 01:49 PM
sounds good except the lunati crank and cam,we stopped using lunati after some problem with there stuff,its junk.look to comp for a cam,and eagle for a crank and rods.
